工程资源中心
直播中
王玉华
7年用户 147经验值
私信 关注
低BOM率成本实现高采样率和良好分辨率的多ADC交错模拟前端设计
            This reference design demonstrates how to achieve multiple ADC interleaving with high sampling rates and good resolution at low BOM-cost. The reference design was built with electronic imaging systems in mind. High definition imaging and other high speed signal processing applications require ADCs  (...)
主要特色
  • Resolution: 14-bit
  • input type: unipolar single-ended
  • SNR > 73dB, ENOB: 12-bit, THD < -80dB
  • Power: < 33mW
  • Low latency compared to pipeline ADC-based solution
  • Small form factor: 22mm x 13mm
更多回帖
