extern _ARMABI int fprintf(FILE * __restrict /*stream*/,
const char * __restrict /*format*/, ...) __attribute__((__nonnull__(1,2)));
* writes output to the stream pointed to by stream, under control of the
* string pointed to by format that specifies how subsequent arguments are
* converted for output. If there are insufficient arguments for the format,
* the behaviour is undefined. If the format is exhausted while arguments
* remain, the excess arguments are evaluated but otherwise ignored. The
* fprintf function returns when the end of the format string is reached.
* The format shall be a multibyte character sequence, beginning and ending
* in its initial shift state. The format is composed of zero or more
* directives: ordinary multibyte characters (not %), which are copied
* unchanged to the output stream; and conversion specifiers, each of which
* results in fetching zero or more subsequent arguments. Each conversion
* specification is introduced by the character %. For a description of the
* available conversion specifiers refer to section 4.9.6.1 in the ANSI
* draft mentioned at the start of this file or to any modern textbook on C.
* The minimum value for the maximum number of characters producable by any
* single conversion is at least 509.
* Returns: the number of characters transmitted, or a negative value if an
* output error occurred.
#pragma __printf_args
extern _ARMABI int
_fprintf(FILE * __restrict /*stream*/,
is equivalent to fprintf,
but does not support floating-point formats.
* You can use instead of fprintf to improve code size.
* Returns: as fprintf.
extern _ARMABI int printf(const char * __restrict /*format*/, ...) __attribute__((__nonnull__(1)));
* is equivalent to fprintf with the argument stdout interposed before the
* arguments to printf.
extern _ARMABI int _printf(const char * __restrict /*format*/, ...) __attribute__((__nonnull__(1)));
* is equivalent to printf, but does not support floating-point formats.
* You can use instead of printf to improve code size.
* Returns: as printf.
extern _ARMABI int
sprintf(char * __restrict /*s*/, const char * __restrict /*format*/, ...) __attribute__((__nonnull__(1,2)));
is equivalent to fprintf, except that the argument s specifies an array
* into which the generated output is to be written, rather than to a
* stream. A null character is written at the end of the characters written;
* it is not counted as part of the returned sum.
* Returns: the number of characters written to the array, not counting the
* terminating null character.
extern _ARMABI int
vsprintf(char * __restrict /*s*/,
const char * __restrict /*format*/, __va_list /*arg*/) __attribute__((__nonnull__(1,2)));
is equivalent to sprintf, with the variable argument list replaced by
* arg, which has been initialised by the va_start macro (and possibly
* subsequent va_arg calls). The vsprintf function does not invoke the
* va_end function.
* Returns: the number of characters written in the array, not counting the
看stdio.h头文件里面,我颜色标明的部分,已经说明不支持float了。
extern _ARMABI int _fprintf(FILE * __restrict /*stream*/,
* is equivalent to fprintf, but does not support floating-point formats.
extern _ARMABI int sprintf(char * __restrict /*s*/, const char * __restrict /*format*/, ...) __attribute__((__nonnull__(1,2)));
* is equivalent to fprintf, except that the argument s specifies an array
extern _ARMABI int vsprintf(char * __restrict /*s*/,
* is equivalent to sprintf, with the variable argument list replaced by
* va_end function.
举报
