工程资源中心
直播中
杨文田
8年用户 135经验值
私信 关注
[电源设计]
集成700V开关的PSR准谐振非隔离式反激式电源
            A quasi-resonant non-isolated Flyback supplies 15V @ 400mA from universal input voltage (90Vac to 265Vac). A LC filter has been added on input terminals to comply with CENELEC EN50065-1 regulations and make this power supply suitable for Power Line Communication. The efficiency curve value remains  (...)
主要特色
  • Simple non-isolated PSR flyback converter with integrated 700V FET
  • Compact solution (28.4mm x 67.4mm) supplies 6W with almost flat efficiency from 50mA to 400mA load (72%...85%)
  • Good output voltage regulation versus load: +/-5% in the whole temperature range
  • Very low noise solution, suitable for PLC  (...)
更多回帖
