我们将E8361A升级到CPU 1.1GHz的A.07.50.48之后仍然存在问题。
我仍然可以看到10MHz的尖峰大约1.8-2dB。
我还检查复选框在低频率下降低IF BW,应用平均因子= 5并尝试打开平滑。
以上所有方法都无法改善10MHz的尖峰。
如果您仍然知道如何改进它,请告诉我。
谢谢。
以上来自于谷歌翻译
以下为原文
The problem still there after we upgrade E8361A to A.07.50.48 for CPU 1.1GHz. I still can see the spike at 10MHz about 1.8-2dB.
I also check the checkbox reduce IF BW at Low frequencies, apply Averaging factor=5 and also try to turn on the smoothing.
All method above not able to improve the spike at 10MHz.
If you still have any idea how to improve it please let me know.
Thanks.
如果您仍然知道如何改进它,请告诉我。
谢谢。
以上来自于谷歌翻译
以下为原文
Thanks.
举报
