工程资源中心
直播中
李佳
7年用户 177经验值
私信 关注
[电源设计]
PMBus 12V/300W系统电源解决方案
PMP11399 is a complete PMBus power system for 3 ASIC/FPGA cores, DDR3 core memory, VTT termination, and auxiliary voltages commonly found on high-performance Ethernet Switches. The hardware is accompanied by a GUI that allows the user to perform real-time configuration and monitoring of the power  (...)
主要特色
  • 12V / 300W system power solution with nine point-of-load buck converters
  • PMBus communication configures hot-swap, SWIFT buck converters, multiphase PWM controller, and power sequencer/supervisor
  • High-density power conversion utilizing Inductor On Top of IC layouts
  • Voltage margining through PMBus and  (...)
更多回帖
