ST意法半导体
直播中
李青
8年用户 189经验值
私信 关注
[问答]
LIS3DH最佳操作规程
我目前正在使用LIS3DH来获取一些加速度数据。目前我的操作模式是首先在旁路模式下初始化器件并配置剩余的参数,然后在需要时将器件重新配置为FIFO模式,在此模式下轮询DRDY信号,直到我的样本总数为止,然后我将设备重新置于旁路模式。
我注意到当我按照上面的过程进行单次读取然后在某个时刻返回以执行另一次读取时,我获得了重复值。这使我重新评估了我的操作方法。
回到AN3308我注意到我可以将电源模式切换为断电。如果我使用I1_ZYXDA位(应该在配置ODR之前设置)来设置DRDY信号,如果我在关闭器件之前禁用FIFO_EN(CTRL_REG5),则会产生以下结果?
要么
有没有更好的方法来实现我想要的功能?
提前致谢!
#lis3dh #config#an3308
以上来自于谷歌翻译
以下为原文
I am currently using the LIS3DH to obtain some acceleration data. Currently my mode of operation is to first initialise the device in Bypass mode and to configure the remainder of the parameters, then when required the device is re-configured into FIFO mode where I poll the DRDY signal until my total number of samples have been taken, then I put the device back into Bypass mode.
I have noticed that when I follow the above process for a single read and then return at some point later to perform another single read I obtain a repeated value. This has led me to re-evaluate my method of operation.
Going back to AN3308 I have noticed that I can instead switch the power mode to power down. This brings about the following, if I am using the I1_ZYXDA bit (which is supposed to be set before configuring the ODR) to set the DRDY signal should I be disabling FIFO_EN (CTRL_REG5) prior to powering the device down?
OR
Is there a better way to go about achieving my desired functionality?
Thanks in advance!
#lis3dh #config #an3308
回帖(2)
曾玲娟
2018-11-29 10:36:30
对不起,但我不清楚你想要什么功能,能否请你更多地说明。
我只有两个评论:
- 您可以使用FIFO阈值中断,当一定数量的样本存储在FIFO中时将触发中断(而不是轮询DRDY信号并自行计算样本数)
- 在数据读取之前,应检查STATUS_REG中的ZYXDA位,以避免多次读取相同的输出值
以上来自于谷歌翻译
以下为原文
I'm sorry but it is not clear to me what is you desired functionality, can you please descibe it more.
I have just a two comments:
- you can use FIFO threshold interrupt which will trigger the interrupt when certain number of samples is stored in FIFO (instead of polling DRDY signal and counting the number of samples by yourself)
- you should check ZYXDA bit in STATUS_REG before data reading to avoid multiple reading of the same output value
举报
李青
2018-11-29 10:46:31
谢谢您的回复。
简而言之,我正在为我的MCU加电并使用我想要的参数初始化加速度计,然后将其置于断电模式。然后,当提示MCU将加速度计置于活动状态(设置ODR值)并等待INT1上的ZYXDA拉高然后读取,然后在放入加速度计之前重复所需的样本总数进入省电模式。我没有使用FIFO功能,因为MCU在此期间无需处理,因此在INT1线上。
我写入器件的过程和每个寄存器的值如下:
TEMP_CFG_REG = 0xC0 //启用温度传感器和ADC
CTRL_REG2 = 0 //无过滤要求
CTRL_REG4 = 0 // Fs = 2g,8位分辨率
CTRL_REG6 = 0 //中断极性高电平有效
FIFO_CTRL_REG = 0x80 /​​/流模式,INT1上触发中断
CTRL_REG3 = 0x10 // ZYXDA_ENCTRL_REG5 = 0 // FIFO禁用
CTRL_REG1 = 0x4F // 50Hz,8位分辨率,XYZ轴'启用
以上来自于谷歌翻译
以下为原文
Thank you for your reply.
In brief, I am powering up my MCU and initialising the accelerometer with my desired parameters and then putting it into power down mode. Then when prompted the MCU puts the accelerometer into an active state (sets the ODR value) and waits for the ZYXDA on INT1 to be pulled high and then takes a reading, this is then repeated for the total number of required samples before putting the accelerometer  into Power Down mode. I am not using the FIFO functionality as the MCU has nothing to process in the meantime and therefore pends on the INT1 line.
My process for writing to the device and each registers value is as follows:
TEMP_CFG_REG = 0xC0 // Temperature sensor and ADC enabled
CTRL_REG2 = 0 // No filtering requirements
CTRL_REG4 = 0 // Fs = 2g, 8 Bit Resolution
CTRL_REG6 = 0 // Interrupt Polarity Active High
FIFO_CTRL_REG = 0x80 // Stream mode, interrupt triggered on INT1
CTRL_REG3 = 0x10 // ZYXDA_ENCTRL_REG5 = 0 // FIFO Disabled
CTRL_REG1 = 0x4F // 50Hz, 8 Bit resolution, XYZ axis' enabled
举报
更多回帖
