我猜你使用Momentum而不是ADS FEM,对吗?
在这种情况下,矩阵的大小非常大,网格摘要如下所示。
============================ ------ MOMENTUM STATISTICS(MW模式)------ Momentum MomEngine_64 11.20。
015(*)2014.01 2014年1月10日Tue Jan 21 01:49:21 2014 =================================
----------------------- MESH --------------------------
- 频率:1 GHz矩形单元:5512四边形单元:70052三角形单元:58795通孔单元:81630边缘电流:281245 ------------------------
---- SOLVER USER TIME ELAPSED TIME MEMORY PROCESSES(h:m:s)(h:m:s)(MB)----------------------
------ SIMULATION SET-UP -----------------初始化|
0:0:41 |
0:0:43 |
815.50端口分析|
0:0:0 |
0:0:0 |
0.01网格处理|
0:4:46 |
0:4:46 |
1903.05矩阵尺寸:483255缩小矩阵尺寸:74106估计工艺尺寸:19649.10 MB ----------------------------------
-------------------------------------------- TOTALS -----
-----------------------物理内存:2730.78 MB虚拟内存:2724.16 MB页面错误:882548用户时间:0h 5m27s经过时间:0h 5m30s ===
=========================此设置是目前所有3D过孔和导体。
但您需要简化设计,以便在合理的时间内对其进行仿真。
建议的矩阵大小低于35,000 ...
以上来自于谷歌翻译
以下为原文
I guess you use Momentum not ADS FEM, right?
In that case, the size of matrix is quite big and the mesh summary is shown below.
------ MOMENTUM STATISTICS (MW mode) ------
Momentum MomEngine_64 11.20.015 (*) 2014.01 Jan 10 2014
MESH
Frequency : 1 GHz
Rectangular cells : 5512
Quadrangular cells : 70052
Triangular cells : 58795
Via cells : 81630
Edge currents : 281245
PROCESSES (h:m:s) (h:m:s) (MB)
SIMULATION SET-UP
Initialization | 0: 0:41 | 0: 0:43 | 815.50
Ports analysis | 0: 0: 0 | 0: 0: 0 | 0.01
Mesh processing | 0: 4:46 | 0: 4:46 | 1903.05
Matrix size : 483255
Reduced matrix size : 74106
Estimated process size : 19649.10 MB
TOTALS
Physical memory : 2730.78 MB
Virtual memory : 2724.16 MB
Page faults : 882548
User Time : 0h 5m27s
Elapsed Time : 0h 5m30s
The setup is all 3D vias and conductors at the moment. But you need to simplify the design in order to simulate it in a reasonable time. The recommended size of matrix is below 35,000...
0:0:41 |
0:0:43 |
815.50端口分析|
0:0:0 |
0:0:0 |
0.01网格处理|
0:4:46 |
0:4:46 |
建议的矩阵大小低于35,000 ...
以上来自于谷歌翻译
以下为原文
MESH
Frequency : 1 GHz
Via cells : 81630
SIMULATION SET-UP
TOTALS
举报
