如果您进行EMI / EMC仿真并且喜欢包括BJT等有源器件,那么您是对的。
您可以测量(或模拟)器件引脚上的电压电平(CSV格式)并将其导入EMPro。
您可以使用导入的波形分配引脚电压以进行EMI计算。
以上来自于谷歌翻译
以下为原文
If you do EMI/EMC simulation and like to include the active devices such as BJT, yes you are right. You can measure (or simulate) the voltage level at the device pins (CSV format) and import them into EMPro. You can assign the pin voltage with that waveform you imported for EMI calculation.
以上来自于谷歌翻译
以下为原文
举报
