是德科技
直播中
杨文英
8年用户 188经验值
私信 关注
[问答]
怎么使用Benchvue保存分段数据
我进行了升级,使我的MSO-X 2024A示波器能够进行分段存储器采集。
我现在有四个通道中每个通道包含250个段的数据,并且需要自动将其保存到我的计算机上(最好是二进制格式,或者以最快的方式) - 我无法弄清楚如何做到这一点
在Benchvue中,看起来它只保存了当前的细分市场。
我想知道是否可以将所有250个段保存到我的计算机上,如果可以,怎么样?
谢谢
以上来自于谷歌翻译
     以下为原文
  I have the upgrade to make my MSO-X 2024A scope capable of segmented memory acquisition. I now have data which consists of 250 segments, on each of the four channels, and need to automate the saving on it to my computer (preferably in binary format, or whichever is fastest) - I can't figure out how to do this in Benchvue, it looks like it only saves the current segment. I'd like to know if it is possible to save all 250 segments to my computer, and if so, how? Thanks
回帖(1)
王晾其
2018-11-28 11:05:35
嗨biancajs,对不起延迟回复。
在从安捷伦过渡到Keysight期间,我无法发布任何回复。
无法从BenchVue中的范围中检索所有分段内存。
不幸的是,您必须手动选择所需的段,然后捕获该跟踪。
我同意你的意见,应该可以做到这一点,并为此向R& D提交了一份增强请求。
以上来自于谷歌翻译
     以下为原文
  Hi biancajs,
Sorry for the delayed response. During the transition from Agilent to Keysight, I was unable to post any replies.
It is not possible to retrieve all segmented memory from the scope in BenchVue. Unfortunately, you have to manually select the desired segment and then capture that trace. I agree with you that it should be possible to do this, and have submitted an enhancement request to R&D for this.
举报
更多回帖
