为什么他们为什么用MPLAX X出来?我在这里尽我最大的努力,但是它对汇编程序来说根本不起作用。总之,RAN
tiN。我在Inc文件中有断点。这是一个PIC16F1。你可以设置断点,它保持一个坚固的红场(它不会显示为断点)。尽管它被忽视了。他们在一些其他公司文件,但不是这一个。这些文件之间没有明显的区别。有什么想法吗?试试ST微?唯一能让PACKIT3可靠破解的方法是使用“数据0002”。它在每个文件中都有效。它在SIM中也不起作用。
以上来自于百度翻译
以下为原文
Why why why did they come out with MPLAB X? I'm trying my best here but it just doesn't work at all for assembly programs.
Anyway enough ranting.
I have breakpoints in an inc file. It's a PIC16F1. You can set the breakpoint and it stays a solid red square (it doesn't show up as a broken breakpoint). Still though it gets ignored. They work in some of the other inc file but not this one. There is no discernible different between the files. Any ideas? Try an ST micro?
The only way I can get the PICkit3 to break reliably is using 'data 0002'. It works in every file. It also doesn't work in the SIM.
