工程资源中心
直播中
俞丽
7年用户 194经验值
私信 关注
高电流输出的多相可堆叠的服务器设计
            PMP2064 uses the TPS40140 in a stackable configuration to generate a multiphase design capable of high current output. The design is setup for each board to use the TPS40140 IC to generate a 2 phase output at up to 50A. Multiple boards can be linked together to create a large current output. The  (...)
更多回帖
