你好,
我尝试用C造作4.1来编译CYPD3125-40LQXIY笔记本的SDK示例代码。
CGX FW用户指南描述,“这个版本的SDK需要PSoC创建者3.3 DP1(构建9674)或更高”。
首先,我将项目中使用的所有组件更新为最新版本。
接下来,我设置了
ARM的MK通用选项。
最后,构建它。
另外,我可以用创建者3.3来构建这个项目。
创建者在下面显示了许多错误。所以请让我知道如何解决它们。
1)生成错误:错误:LTO包装失败
2)建立错误:命令“ARME EABI GCC .exe”退出代码“1”失败。
3)组件SCBYP4V3Y10的实例“HPIIF IF”包含错误。无法定位和自定义图中使用的组件“SCBYP4V3Y10”
4)组件SCBYP4V3Y10的实例“MUXYCTRL”包含错误。无法定位和自定义图中使用的组件“SCBYP4V3Y10”
5)钳工由于错误而中止,请解决所有错误并重建。
最好的问候,
以上来自于百度翻译
以下为原文
Hello,
I tried to compile SDK sample code of CYPD3125-40LQXI_notebook with Creator 4.1.
CCGx FW UserGuide described, "This version of the SDK requires PSoC Creator 3.3 DP1 (build 9674) or higher".
At first, I update all of the components used in the project to latest version.
Next, I set up the op
tion for ARM MDK Generic.
Finally, build it.
Also, I could build the project with Creator 3.3.
Creator shows many errors below. So please let me know how I can resolve them.
1) Build error: error: lto-wrapper failed
2) Build error: The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
3) The instance 'HPI_IF', of component SCB_P4_v3_10, contains an error. Unable to locate and customize component 'SCB_P4_v3_10' used in schematic
4) The instance 'MUX_CTRL', of component SCB_P4_v3_10, contains an error. Unable to locate and customize component 'SCB_P4_v3_10' used in schematic
5) The fitter aborted due to errors, please address all errors and rebuild.
Best regards,
