工程资源中心
直播中
郑尧
7年用户 202经验值
私信 关注
[LED照明]
针对DLP投影仪应用的RGB LED驱动器解决方案
The PMP4356 is RGB LED drivers solution which used in high power density DLP projector. LM3434 and power block CSD87350 are used in each rail to provide up to 15A of drive ability. The design demostrates high efficiency up to  92.5%@full load within the form factor of 80mm*45mm*10.8mm with good  (...)
更多回帖
