在执行11.3更新后我遇到了同样的问题 - xps.exe启动但在GUI启动之前结束,无论是从命令行,Windows菜单还是从ISE调用。
我没有上面提到的安装错误问题。
SDK运行,但奇怪的是.vbs文件类型已更改为与记事本关联。
我不得不手动将其与Windows脚本主机重新关联。
奇怪的。
如果这是一个Cygwin兼容性问题,我不会感到惊讶,但清除缓存不起作用,也不会手动重新调整注册表。
我有一个类似的问题9.2与单独的Cygwin安装不好玩(见答案记录#23716和#24134)。
如果这是一个类似的问题,我没有时间搞清楚,我仍然需要使用9.2安装来维护旧项目。
我只是吹掉它并重新安装11.1-> 11.2。
如果有人在将来遇到解决方案,我很乐意听到它。
问候,
杰夫贝克特
高级电子工程师
火山公司
***eckett@volcanocorp.com
以上来自于谷歌翻译
以下为原文
I experienced the same problem after doing the 11.3 update -- xps.exe starts but ends before its GUI comes up, either from the command line, the Windows menus, or invoked from ISE. I did not have the installation error problem mentioned above. The SDK runs, but oddly the .vbs file type had been changed to associate with notepad. I had to manually reassociate it with the Windows scripting host. Weird.
I would not be surprised if this is a Cygwin compatibility problem, but clearing the cache doesn't work, nor does manually realigning the registry. I had a similar problem with 9.2 not playing nice with a separate Cygwin installation (see answer records #23716 and #24134).
If this is a similar problem, I haven't the time to figure it out, and I still need to use the 9.2 installation for maintaining older projects. I'm just blowing it all away and reinstalling 11.1->11.2. If anyone comes across a solution in the future, I'd love to hear about it.
Regards,
Jeff Beckett
Senior Electronics Engineer
Volcano Corporation
我没有上面提到的安装错误问题。
奇怪的。
问候,
杰夫贝克特
高级电子工程师
火山公司
以上来自于谷歌翻译
以下为原文
Regards,
Jeff Beckett
Volcano Corporation
举报
