英特尔
直播中
郭欣
8年用户 210经验值
私信 关注
[问答]
HNS7200AP卡在邮政编码0x19:SB PEIM
嗨,
我一直试图在HNS7200AP计算模块上获得一个KNL来发布,但它似乎停留在邮政编码0x19:SB PEIM,偶尔会重置自己并且ges再次卡住。
有关于如何调试此问题的任何建议吗?
所有帮助表示赞赏。
谢谢,
布赖恩
以上来自于谷歌翻译
以下为原文
Hi,
I've been trying to get a KNL on the HNS7200AP compute module to post, but it seems to be stuck at post code 0x19: SB PEIM, and occasionally resets itself and ges stuck again. Are there any suggestions on how to debug this issue?
All help is appreciated.
Thanks,
Brian
回帖(15)
汤宇
2018-11-21 12:01:32
您好Brian,为了更好地了解您的问题,请通过提供更多附加信息来帮助我们:您的系统有多少内存?您有什么设备连接到HWS7200AP?这是您第一次获得此POST代码
?您最近是否在系统中添加了新设备?您当前运行的操作系统是什么?您目前的BIOS版本是什么?最好的问候,Sergio S.
以上来自于谷歌翻译
以下为原文
Hello Brian,
In order to better understand your problem, help us by providing more additional information:
How much memory do you have on your system?
What devices do you have connected to the HNS7200AP?
Is this the first time that you are getting this POST code?
Did you recently add a new device to your system?
What operating system are you currently running?
What is the current BIOS version that you have?
Best regards,
Sergio S.
举报
李玉鑫
2018-11-21 12:17:25
嗨塞尔吉奥,
尚未安装操作系统。
这是我第一次启动该模块。
在dimm插槽A / B(16gb ea)上安装了两个dimms。
没有设备添加到系统中。
BIOS ID为“S72C610.86B.01.02.0001.112820162103”
谢谢,
布赖恩
以上来自于谷歌翻译
以下为原文
Hi Sergio,
There is no operating system installed yet. This is my first boot up of the module.
There are two dimms installed on dimm slots A/B (16gb ea). No device has been added to the system.
The BIOS ID is "S72C610.86B.01.02.0001.112820162103"
Thanks,
Brian
举报
汤宇
2018-11-21 12:32:47
引用: cd340823 发表于 2018-11-21 11:55
嗨塞尔吉奥,
尚未安装操作系统。
这是我第一次启动该模块。
您好布莱恩,我们感谢您的回复。作为故障排除建议,请在您的系统上执行BIOS更新至版本R01.03.0018。
请单击此处获取更多信息。此外,使用最小配置启动系统,只需一个内存模块,无需连接硬盘驱动器。最重要的是,Sergio S.
以上来自于谷歌翻译
以下为原文
Hello Brian,
We appreciate your reply.
As troubleshooting suggestion, please perform a BIOS update on your system to version R01.03.0018. Please click herefor more information.
Additionally, boot your system with the minimal configuration, just one memory module and no hard drives connected.
Best regards,
Sergio S.
举报
郭欣
2018-11-21 12:50:27
嗨塞尔吉奥
我无法更新BIOS。
我已将跳线设置为BIOS恢复并将您发送的链接中的内容复制到闪存驱动器(u***2,fat32),但似乎没有读取u***。
事件日志显示模块已启动BIOS恢复过程,邮政编码显示为0xF1。
但是一段时间后硬件会自行重置。
我已经分离了所有设备,并使用一个内存dimm启动。
还有什么我可以尝试的吗?
谢谢,
布赖恩
以上来自于谷歌翻译
以下为原文
Hi Sergio
I am unable to update the BIOS. I've set the jumper to BIOS recovery and copied the contents from the link you sent  to a flash drive (u***2, fat32) but the u*** does not seem to be read. The event logs show that the module has started the BIOS recovery process and the post code is shown as 0xF1. However after a while the hardware resets itself.
I've detached all devices and booted with one memory dimm. Is there anything else I can try?
Thank you,
Brian
举报
更多回帖
