引用: tianyou15 发表于 2018-11-21 12:38
你最初有这种能力,然后似乎失去了它?
在笔记本电脑设计中,坚持使用笔记本电脑制造商提供的驱动程序非常重要,因为它们可能已被制造商修改以支持笔记本电脑的特定功能和/或设计细微差别。
使用英特尔网站上的通用驱动程序进行更新可能会导致意外问题并禁用这些独特功能。
嗨斯科特,
感谢您的信息和快速响应,这真的很有帮助!
这个问题是开箱即用的,我觉得有些升级功能与无法调整屏幕亮度相比不起作用。
所以我所做的就是去你的网站并下载最新的驱动程序,然后安装它。
重启后一切似乎都正常。
我现在可以改变亮度,“夜间模式”(蓝光滤镜)功能也可以。
如果我遇到任何图形问题,我会假设安装最新驱动程序而不是坚持使用笔记本电脑制造商安装的驱动程序是我的错。
只有一个显卡,但正如你所说,我可能还有其他原因,他们选择了驱动程序版本。
很抱歉,如果此消息中的术语不太有意义,我对这些事情并不熟悉
再次感谢你的帮助!
克里斯
以上来自于谷歌翻译
以下为原文
Hi Scott,
Thanks for the info and the fast response, that's really helpful!
The issue was straight out of the box and I feel like some upgraded features not working pales in comparison with not being able to adjust the screen brightness. So what I've done is gone to your website and downloaded the most recent drivers, then installed that. After a restart everything seems to work normally. I can now change the brightness and the "night mode" (blue light filter) feature is working too. If I come across any graphics issues, I'll just assume that it's my fault for installing the latest driver instead of sticking with the one the laptop manufacturer had installed. There is only one graphics card, but as you say, there may be other reasons beyond my understanding that they chose the driver version.
Sorry if the terminology in this message doesn't quite make sense, I'm not well versed in these things
Thanks again for your help!
Chris
你最初有这种能力,然后似乎失去了它?
嗨斯科特,
重启后一切似乎都正常。
再次感谢你的帮助!
克里斯
以上来自于谷歌翻译
以下为原文
Hi Scott,
Chris
举报
