赛灵思
直播中
张玲
8年用户 1348经验值
私信 关注
[问答]
重新安装Matlab后如何重新安装System Generator
以前,我们有matlab 2006a和ISE 8.2i,并且正在使用System Generator。
我们不得不重新安装Matlab 2006a以启用新的工具箱,但现在Simulink中没有System Generator。
我已使用下载站点上提供的WebPACK_82i_SFD.exe重新安装了ISE 8.2i。
但是,系统生成器仍然不可用。我需要做什么才能将系统生成器“重新安装”到Matlab中?谢谢!--- Mike VanHornmichael.vanhorn@wright.edu
--- Mike VanHorn
以上来自于谷歌翻译
以下为原文
Previously, we had Matlab 2006a and ISE 8.2i, and were using the System Generator. We had to reinstall Matlab 2006a to enable a new toolbox, but now the System Generator is not available in Simulink. I have re-installed ISE 8.2i using the WebPACK_82i_SFD.exe available on the download site. However, the System Generator still isn't available. What do I need to do to "re-install" the System Generator into Matlab? Thanks! ---Mike VanHornmichael.vanhorn@wright.edu ---
Mike VanHorn
回帖(6)
王林
2018-11-19 14:52:27
您只需转到已安装ISE Design Suite的目录即可。
然后运行'sg_config.exe',在这种情况下你可以选择你的matlab。
例如,D: Xilinx  10.1  DSP_Tools  common  bin  sg_config.exe
以上来自于谷歌翻译
以下为原文
You can just go to the directory where the ISE Design Suite have been installed. Then ran the 'sg_config.exe', in this case you can select your matlab. For example, D:Xilinx10.1DSP_Toolscommonbinsg_config.exe
举报
石栓柱
2018-11-19 15:06:03
我在我的系统上找不到“sg_config.exe”文件。
奇怪的是,在C: Program Files  Matlab  2006a  toolbox目录中,有一个Xilinx目录,但Xilinx块集在Simulink LIbrary浏览器中不可用。
那么,也许我应该问的问题是如何重新安装Xilinx模块组?
--- Mike VanHorn
以上来自于谷歌翻译
以下为原文
I can't find a "sg_config.exe" file anywhere on my system.
What's weird is that in the C:Program FilesMatlab2006atoolbox directory, there is a Xilinx directory, but the Xilinx blockset isn't available in the Simulink LIbrary Browser. So, perhaps the question I should be asking is how to re-install the Xilinx blockset?
Mike VanHorn
举报
李林
2018-11-19 15:18:07
sg_config.exe随System Generator一起安装。
它在%XILINX_IDS_INSTALL_DIR% DSP_Tools  nt  common  bin中
干杯,吉姆
以上来自于谷歌翻译
以下为原文
sg_config.exe is installed with System Generator. It's in %XILINX_IDS_INSTALL_DIR%DSP_Toolsntcommonbin
Cheers,
Jim
举报
石栓柱
2018-11-19 15:23:59
抱歉,系统上没有任何sg_config.exe,也没有DSP_Tools目录。
你确定这应该适合8.2i吗?
我认为旧软件的功能有类似之处,但也许它位于不同的地方?
迈克范霍恩
--- Mike VanHorn
以上来自于谷歌翻译
以下为原文
Sorry, there isn't an sg_config.exe anywhere on the system, nor is there a DSP_Tools directory. Are you sure this is supposed to be right for 8.2i? I would imagine there is something similar in functionality for the older software, but perhaps it's in a different place?
Mike VanHorn
Mike VanHorn
举报
更多回帖
