是德科技
直播中
王莉淳
7年用户 260经验值
私信 关注
[问答]
E5071C能将轨迹分配给窗口吗
大家好,我的ENA配置了8个窗口,如附图所示,12个跟踪。
我想配置显示器,因此左侧只显示1个跟踪窗口列,右侧列显示2个跟踪。
这可能吗?
当我尝试设置它时,它似乎只配置自己的前4个窗口有2条跟踪,以下4个有1条跟踪。
谢谢PaulEdited:2014年9月4日上午11:03分析器100
以上来自于谷歌翻译
     以下为原文
  Hi All,
I have my ENA configured with 8 windows as shown in the attached picture, and 12 traces.
I would like to configure the display, so only 1 trace is shown on the left had column of windows, and 2 traces on the right hand column. Is this possible?
When I try to set this up, it just seems to configure itself with the first 4 windows having 2 traces, and the following 4 having 1 trace.
Thanks,
Paul
Edited by: analyzer100 on Sep 4, 2014 11:03 AM
附件
回帖(3)
h1654155275.5614
2018-11-15 16:44:16
我不是ENA专家,但我的桌子上有一个。
所以我很好奇是否可以这样做。
我无法想办法完全按照你想要的方式行事,但我确实认为你可以去16条痕迹,每边8条,然后它们有一个关闭数据的功能。
因此,在左侧,对于½轨迹,您可以关闭数据。
标签仍然留在那里,所以它不干净,但你没有看到痕迹。
这样,左侧有四条活动迹线,右侧有8条活动迹线。
Afsi Moaveni
以上来自于谷歌翻译
     以下为原文
  I am not an ENA expert, but I have one at my desk. So I was curious if this could be done. I couldn’t figure a way to do what you wanted exactly, but I did figure you can go to 16 traces, so 8 on each side, and then they have a feature to turn data off.
So on the left side, for ½ the traces you turn data off. The label still stays there, so it’s not clean, but you don’t see a trace.  That gives you four active traces on the left, 8 active traces on the right.
Afsi Moaveni
举报
王莉淳
2018-11-15 16:55:39
引用: dsgdadsad 发表于 2018-11-15 08:45
我不是ENA专家,但我的桌子上有一个。
所以我很好奇是否可以这样做。
感谢您的建议。
它看起来有点混乱,但似乎这是你能做到这一点的唯一方法。
谢谢您的帮助!
以上来自于谷歌翻译
     以下为原文
  Thank you for the suggestion.
It looks a little messy like that, but it seems like that's the only way you can do this.
Thanks for the help!
举报
王莉淳
2018-11-15 17:05:58
我不是ENA专家,但我的桌子上有一个。
所以我很好奇是否可以这样做。
以上来自于谷歌翻译
     以下为原文
举报
更多回帖
