赛灵思
直播中
王鹏飞
8年用户 174经验值
私信 关注
[问答]
Common 17-49内部数据异常
Detailed_Desc:•[Common 17-49]内部数据异常:ProcHandler :: InvalidParam
软件在实施过程中崩溃,没有给我的信息,应用程序建议我在这里发布。
我已经在这个项目上工作了好几个月而没有这次崩溃。
Os_Version:w10
VivadoSw_2017.4
以上来自于谷歌翻译
以下为原文
Detailed_Desc: •       [Common 17-49] Internal Data Exception: ProcHandler::InvalidParam
Software is crashing during implementation, no information given to me, apps eng recommend I post here.  I have been working on this project for months without this crash.
Os_Version: w10
VivadoSw_2017.4
回帖(1)
赵雪培
2018-11-13 14:39:46
@tkleman
你能分享vivado.log吗?
这是项目特定的崩溃还是任何vivado项目?
确保目录路径中没有特殊字符和空格,并且还要避免longdirectory路径长度。
检查Vivado命名约定的以下链接:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug895-vivado-system-level-design-entry.pdf#page=124
尝试减少Project工作目录的路径长度。
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
@tkleman
Can you share vivado.log? Is this a project specific crash or for any vivado projects?
Make sure there are no special characters and spaces in the directory path and also avoid long directory path length.
Check the following link on Vivado naming conventions:
Try reduce the path length of the Project working directory.
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
举报
更多回帖
