| Category | Questions | Answers (N/A if not applicable) | |
| Description | Provide a detailed description of the issue | When exporting 4k footage in Adobe Premiere with Hardware Acceleration enabled the exported video shows green flickering and glitching. Task Manager shows the dedicated graphics are not being used properly | |
| Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often") | Always (100%): X Often (51-99%): Sporadic (20-50%): Very Sporadic (<20%): | ||
| Hardware (HW) | Brand and Model of the system. | HP Spectre X360 | |
| Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too? | Hybrid AMD graphics. | ||
| Make and model of any Displays that are used to see the issue (see note2 below). LFP = Local Flat Panel (Laptop panel) EFP = External Flat Panel (Monitor you plug in) | Intel(R) HD Graphics 630 Radeon RX Vega M GL Graphics | ||
| How much memory [RAM] in the system (see note2 below). | 16GB | ||
| Provide any other hardware needed to replicate the issue. ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc | NA | ||
| Hardware Stepping (see note1 below). | Included as an attachment | ||
| Software (SW) | Operating System version (see note2 below). | Operating System: Microsoft Windows 10 Home(10.0.17134 Build 17134) | |
| VBIOS (video BIOS) version. This can be found in “information page” of CUI (right click on Desktop and select “Graphics Properties”. | f.21. HPQOEM -1072009 | ||
| Graphics Driver version; for both integrated Intel and 3rd party vendors (see note2 below). | Intel: 23.20.16.4973 Vega: 23.20.792.1280 | ||
| SW or Apps version used to replicate the issue. | Adobe Premiere (most up to date version) Adobe Media Encoder (most up to date version) | ||
| Configurations | Single display, clone, or extended (see note2 below). | Single | |
| Display resolution & refresh rate setting of each display (see note2 below). | 3840x2160 60hz | ||
| AC or DC mode, i.e. is power cable plugged in or not? | Both Plugged in and Unplugged | ||
| How to repro | Please provide steps to replicate the issue. These steps are very crucial to finding the root cause and fix. A screenshot to illustrate the issue is a huge plus. A video of the failure is even better! Attach to the post or provide the YouTube link. |
举报
引用: jerry1978 发表于 2018-11-12 12:07
HelloVegaMGLfailure,我知道你在使用Vega M GL的Adobe Premiere时遇到了问题。关于这一点,我将非常乐意帮助你并通过复制它来检查问题,看看它是否显示相同的行为。
但是,我需要有关系统的更多信息,特别是系统支持实用程序和DxDiag。
可以使用我们的工具生成系统支持实用程序报告,您可以参考以下链接以便下载:https:/ ...
举报
引用: cd340823 发表于 2018-11-12 12:14
首先,我想对我的帖子格式不佳表示道歉,这是因为复制粘贴失败导致的。
我已将摘要视图系统实用程序截图附加到此帖子。
我还附上了一份全文dxdiag报告。
举报
我还附上了一份全文dxdiag报告。
举报
更多回帖
