Hello_tyoc213_,我知道你在运行“vulkaninfo”应用程序时收到Vulkan的错误消息。关于这一点,我正在现场测试问题,我能够找到一个我们可以尝试的解决方案。
我可以确认这是成功修复了错误,因为我也得到了它。
请尝试使用干净的驱动程序安装,让我们按照以下步骤开始:1 - 从https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10下载.zip驱动程序?
product = 883552 - 断开计算机与Internet的连接.3 - 转到设备管理器并在显示适配器下查看.4 - 右键单击英特尔®集成显卡,选择卸载并继续操作,直到只有Microsoft的基本显示适配器
.5 - 解压缩您之前下载的文件.6 - 右键单击Microsoft的基本显示适配器并选择“更新驱动程序”.7 - 选择“浏览计算机以查找驱动程序软件”.8 - 选择选项“我选择
从我计算机上的设备驱动程序列表“.9 - 选择”有磁盘“选项.10 - 选择”浏览“选项.11 - 访问解压缩下载驱动程序的指定位置或文件夹,并访问名为”
图形“.12 - 选择设置信息文件(通常命名为”id
glh64“或”igdlh“)。13 - 单击打开然后单击确定,最后单击下一步,驱动程序将开始安装.14 - 安装完成后重新启动计算机。完成此操作后运行”vulkaninfo“
“它不应该再给你错误了。我希望这会有所帮助。大卫V.
以上来自于谷歌翻译
以下为原文
Hello
_tyoc213_,
I understand that you are getting an error message with Vulkan when running the "vulkaninfo" application.
Regarding this, I was testing the problem myself on-site and I was able to find a solution which we can try. I can confirm that this successfully fixed the error since I was getting it as well. Please try with a clean driver installation, lets start by following the steps below:
1 - Download the .zip driver from
https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10?product=88355
2 - Disconnect the computer from the internet.
3 - Go to device manager and check under display adapters.
4 - Right-click on the Intel ® Integrated Graphics, select the option uninstall and keep going until you only have Microsoft's basic display adapter.
5 - Unzip the file you downloaded previously.
6 - Right-click on the Microsoft's basic display adapter and select "Update driver".
7 - Select the option "Browse my computer for driver software.
8 - Select the option "Let me pick from a list of device drivers on my computer".
9 - Select the option "Have disk".
10 - Select the option "Browse".
11 - Access the designated location or folder where you unzipped the driver downloaded and access a folder called "Graphics".
12 - Select the setup information file (Typically named either "idglh64" or "igdlh").
13 - Click on open and then click OK, finally click Next and the drivers will begin to install.
14 - Reboot your computer when the installation is completed.
After this is completed and you run the "vulkaninfo" it should not give you the error anymore.
I hope this helps.
Regards,
David V
以上来自于谷歌翻译
以下为原文
Hello
_tyoc213_,
I hope this helps.
Regards,
David V
举报
