如果你碰巧有一个4端口PNA,那么你可以简单地做一个3端口Smart Cal,其中两个端口连接器类型设置为Waveguide,并且为这些端口选择R11664A calkit,第三个端口设置为连接器类型
同轴耦合端口,您为该同轴连接器选择适当的calkit。
当您执行校准时,将提示您为每个端口提供适当的标准,但是您还需要有一个波导来同步适配器以用于未知的直通步骤(未知通过默认的直通方法)。
如果你只有2个PNA,那么你需要做2端口校准,其中1个端口设置为波导,另一个设置为同样如上所述。
你仍然需要一个波导来哄适配器用于直通步骤。
当您进行测量时,您需要使用波导负载端接未使用的波导端口。
以上来自于谷歌翻译
以下为原文
If you happen to have a 4 port PNA, then you can simply do a 3 port Smart Cal where two of the port connector types are set to Waveguide and the R11664A calkit is selected for those ports and the 3rd port is set to the connector type of the coaxial coupled port and you select the appropriate calkit for that coaxial connector. When you do the cal, the will prompt you for the appropriate standards for each of the ports, but you will also need to have a waveguide to coax adapter for the unknown thru steps (unknown thru is the default thru method).
if you only have a 2 PNA, then you need to do 2-port cal where 1 port is set to waveguide and the other set to coax just as above. you will still need a waveguide to coax adapter for the thru step. when you do the measurement, you will need to terminate the unused waveguide port with a waveguide load.
以上来自于谷歌翻译
以下为原文
举报
