英特尔
直播中
陈可
8年用户 282经验值
私信 关注
[问答]
Intel Unite:无法将客户端连接到Unite服务器
我无法将客户端连接到Intel unite服务器。
我绕过了证书检查和安装服务器,服务器正在运行并生成PIN。
但是,当我将客户端连接到服务器时,我收到此错误:服务器证书不符合最低证书要求。
以上来自于谷歌翻译
以下为原文
I am unable to connect client to Intel unite server. I have bypassed the certificate check and Installed the server, Server is running and generating PIN. But when I am connecting client to server I am getting This Error: The server certificate does not meet the minimum certificate requirement.
回帖(2)
汤宇
2018-11-9 11:31:17
HelloAvinashBeerelli感谢您加入英特尔®社区,请允许我帮助您解决您使用英特尔®Unite®时遇到的问题。
让我知道以下信息:
服务器中心和客户端上的IntelUnite®版本是什么?正在使用哪种证书?
证书是否安装在HUB上?
HUB的型号是什么?
您是否可以在命令提示符下运行以下命令以从IntelUnite®客户端创建日志文件?
请将日志文件附加到线程。“intel unite launcher.exe”/ debug> log_output.txt创建.TXT文件后,将其保存到桌面,使用右下角的“attach”选项将其附加。
谢谢。
此致,莱昂纳多C.
以上来自于谷歌翻译
以下为原文
Hello AvinashBeerelli
Thank you for joining the Intel® community, allow me to help you with the problem that you are having with Intel Unite®.
Let me know the following information:
  • What are the Intel Unite® versions on the server hub and client
  • What kind of certificate is being used?
  • Is the certificate installed on the HUB?
  • What is the model of the HUB?
  • Could you run the following command on the command prompt to create a log file form the Intel Unite® client? Please attach the log file to the thread.
"intel unite launcher.exe" /debug >log_output.txt
Once the .TXT file is created save it to your desktop, attach it by using the option on the lower right corner “attach”.
Thank you.
Regards,
Leonardo C.
举报
李玉鑫
2018-11-9 11:37:48
您好Avinash Beerelli我正在检查您的情况,想知道您是否需要进一步的帮助。
如果是这样,请不要犹豫回复.Regards,Leonardo C.
以上来自于谷歌翻译
以下为原文
I was checking your case and would like to know if you need further help.  If so, please do not hesitate in replying back.
Regards,
Leonardo C.
举报
更多回帖
