如果你指的是DeVHebug和HooST唤醒行,不,它们在固件下载期间不被使用。如果您计划在应用程序中使用它们,可以将引脚配置为活动的高电平或低电平。
以上来自于百度翻译
以下为原文
If you are referring to the DEV_WAKE and HOST_WAKE lines, no, they are not used during firmware download. If you are planning to use them in your application, you can configure the pins as either ACTIVE HIGH or LOW.
以上来自于百度翻译
以下为原文
举报
