您好jordanj,感谢您在英特尔社区发帖。我了解您在设置英特尔®Optane™内存时遇到问题。
根据附带的报告,您的系统似乎与模块兼容。
实际上,系统正在识别模块。让我们首先检查BIOS设置。
您能否告诉我您在BIOS中修改了哪些设置?此外,关于Windows *操作系统,您能否截取磁盘管理窗口的屏幕截图?
要打开磁盘管理,请按Windows键+ x,然后从出现的菜单中选择工具。必须使用GPT分区样式安装Windows *,请您确认它是否已安装?我还在检查
主板的规格和模块显然有一个特定的插槽。
请确保您已将模块连接到正确的插槽中:https://www.asus.com/us/Motherboards/ROG-STRIX-Z370-E-GAMING/specifications/此外,请确保您已更新了BIOS的BIOS
母板。
如果您不确定BIOS版本,我建议您直接联系ASUS *以确保BIOS是最新的:https://www.asus.com/us/Motherboards/ROG-STRIX-Z370-E-
GAMING / HelpDesk /我会等你的回复。祝你有个美好的一天。感谢,Diego V.
以上来自于谷歌翻译
以下为原文
Hi jordanj,
Thank you for posting in the Intel communities.
I understand that you are having issues setting up the Intel® Optane™ Memory. According to the report attached, your system seems to be compatible with the module. Actually, the module is being recognized by the system.
Let’s first check the BIOS settings. Could you please tell me which exactly settings you modified in BIOS?
Additionally, regarding to the Windows* OS, could you please take a screenshot of the Disk Management window? In order to open the Disk Management press the
Windows key + x and then select the tool from the menu that will appear.
Windows* must be installed using a GPT partition style, could you please confirm it was installed like that?
I was also checking the motherboard’s specifications and apparently there is a specific slot for the module. Please make sure you have connected the module in the correct slot:
Additionally, make sure you have updated the BIOS of your motherboard. If you are not sure about the BIOS version, I recommend you to contact ASUS* directly to make sure the BIOS is up to date:
https://www.asus.com/us/Motherboards/ROG-STRIX-Z370-E-GAMING/HelpDesk/
I’ll be waiting for your response.
Have a nice day.
Regards,
Diego V.
主板的规格和模块显然有一个特定的插槽。
母板。
以上来自于谷歌翻译
以下为原文
Hi jordanj,
Have a nice day.
Regards,
Diego V.
举报
