我有一个DSO3034A,我想用一个简单的tcp套接字和Scpi-raw远程控制它。
我实际上可以毫无问题地执行scpi命令,我甚至可以使用“:SYST:SET?”来请求学习字符串。
但问题是我似乎无法将其设置回来。
在文档中提到我应该用“:SYST:SET”将其发回,然后在数据之后。
我尝试过的一个例子:SYST:SET#800083042 expandMode 0,“ground”wfmAn
tialiasing ....更多数据......看起来很简单,但直到现在我都没有成功。
有人可以帮我这个,说我做错了什么?
我使用TcpClient和c#来处理套接字
通信。
谢谢,彼得
以上来自于谷歌翻译
以下为原文
I have a DSO3034A an I want to remote control it using a simple tcp socket and Scpi-raw.
I can actually do execute scpi commands without a problem, I can even requests the learn string using ":SYST:SET?".
But the problem is I don't seem to be able to set it back. In the documentation it is mentioned that I should send it back with ":SYST:SET " and after that following the data.
One of the examples I tried :
:SYST:SET #800083042 expandMode 0,"ground" wfmAntialiasing
more data
It seemed straight forward but I have no success with it until now.
Can someone help me with this, say me what I do wrong ?
I use TcpClient with c# to handle the socket communication.
Thank,
Peter
