如果你找不到MpLabx,那么试试谷歌的NETBeBes,因为MPLABX是基于NETBeNSs的,你会在这里找到位置,但是这可能不是你想要的。HTTPS://StaskOfFult.COM/DISSMS/22698069/WHE-IS-NETBEANS- 8字典- LoATATI也关闭了拼写检查器,但是O对于C…注释,因为它通常不太有用,也不利于代码。请参阅工具/选项/编辑器/拼写检查程序。
以上来自于百度翻译
以下为原文
If you cannot find it for MpLabx, then try to google for netbeans, since MpLabX is based on Netbeans
You will find the location here, but this likely is not what you want.
https://stackoverflow.com/questions/22698069/where-is-the-netbeans-8-dictionary-located
I also turned off the spell checker, but only for C ... comments, because it usually is not that helpful, and distracts from the code.
See Tools / Options / Editor / Spellchecker
以上来自于百度翻译
以下为原文
举报
