你好,
只要BUUTH的FM4-176L S6E2CC-ETH起动器套件。我已经安装了PDLV2.0.2和PDLV2.1.0,并且注意到/PDVL2.0.2/Excel/文件夹包含一个名为/i2s/的文件夹,其中有一个音频示例,但是/PDLV2.1.0/ExpReSe/没有。因为我使用的
ARM GCC编译器没有支持的IDE,所以我需要使用PDLV2.1.0示例中提供的新的东西(例如/ARMGC/DIR)来运行示例,但是尝试将PDVL2.0.2I2S示例与PDLV2.0.1示例结合起来,ARMGCC的东西会产生很多错误(OB)。尤利)
所以,我的问题是:
PDLV2.0.1中是否有I2S示例?
最好的,
峡湾
以上来自于百度翻译
以下为原文
Hello,
just bougth a FM4-176L-S6E2CC-ETH starter kit. I've installed both PDLv2.0.2 and PDLv2.1.0, and no
ticed that /PDLv2.0.2/examples/ folder contains a folder named /i2s/ with one audio example, but /PDLv2.1.0/examples/ not. Since I'm using the ARM GCC compiler with no supported IDE I need to make use of the new stuff provided in the PDLv2.1.0 examples (e.g. /armgcc/ dir) to run the examples, but trying to make the PDLv2.0.2 I2S example in combination with the PDLv2.0.1 example armgcc stuff generates lots of errors (obusly).
So, my question is:
Is there an I2S example in PDLv2.0.1?
Best,
FD
