你好@ tia86
我认为您可以为这些FPGA站点创建pblock并将EXCLUDE_PLACEMENT属性设置为TRUE,以便该工具不会将其他逻辑放入此pblock中。
将要放置在此FPGA区域中的逻辑分配给pblock。
您还可以使用LOC约束将逻辑约束到pblock中的特定站点。
LOC约束将优先考虑。
希望这可以帮助。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi @tia86
I think you can create pblock for those FPGA sites and set the EXCLUDE_PLACEMENT property to TRUE so that the tool does not place other logic in to this pblock. Assign the logic which you want to place in this FPGA region to pblock. You can also have LOC constraint to constrain the logic to specific site within pblock. The LOC constraint would take priority.
Hope this helps.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
你好@ tia86
LOC约束将优先考虑。
希望这可以帮助。
张贴。
以上来自于谷歌翻译
以下为原文
Hi @tia86
Hope this helps.
Thanks,
Deepika.
举报
