Microchip
直播中
钱杨静
8年用户 222经验值
私信 关注
[问答]
Microchip是否RN4020用于在Apple产品上使用Swift程序的库
Microchip是否提供图书馆使我们能够在苹果产品上使用SWIFT编程语言与RN4020模块进行接口?
以上来自于百度翻译
      以下为原文
    Do Microchip offer Libraries to enable us to interface to RN4020 modules using the Swift programming language on Apple products?
回帖(2)
杨叶
2018-11-2 15:12:25
嗨,RN4020是一个老的蓝牙模块。你最好看看RN861或RN48 70,如果它是一个新的设计。据我所记得,有两个在iOS上运行的应用程序,它们可以与RN870/71 PictWin板交互。我不知道它们是用哪种语言编写的,如果源代码可以从微芯片中获得。当然需要在微芯片网站上张贴支持票:HTTP://www. MicroPC.COM/Supple
以上来自于百度翻译
      以下为原文
    Hi,
RN4020 is an old bluetooth module. You should better look at RN4871 or RN4870 if it is for a new design.
As far as I remember there are a couple of apps running on iOS which can interact with the RN4870/71 pictail boards.
I don't know in which language they were written and if the sourcecode can be obtained from Microchip.
You would probably need to post a support ticket on Microchip website : http://www.microchip.com/support
Regards
举报
孙世珍
2018-11-2 15:20:12
RN4020是现有产品中的设备,所以我别无选择。不幸的是,在这种情况下,一个PICTWEN板是不相干的。但是Idoneed是苹果操作系统的库或框架,在SWIFT中编程。我将采纳你在微芯片网站上发布支持票的建议。谢谢。
以上来自于百度翻译
      以下为原文
    The RN4020 is the device in an existing product, so I have no choice. And so a Pictail board in that context is irrelevant, unfortunately. But what I do need is the Libraries or Frameworks for the Apple OS, programmed in Swift.
I will take up your suggestion of posting a support ticket on Microchip's site. Thanks.
举报
更多回帖
