Microchip
直播中
李艳婷
8年用户 246经验值
私信 关注
[问答]
dallas 1线EPROM 12V编程脉冲的I/O保护
系统由USB 5V供电;PIC16F1459是1线主控器,16F1459IO1用于1-线通信;16F1459IOI2被设计为在总线上应用12V(或5V)编程功率;我的问题是:当12V应用于1线时,电路将工作16F1459IO1保护吗?2.当PIC开机或复位(IO2浮动)时,我希望Q3可以快速切断(快于Q1开启时间,抱歉我的英语不好),因此12V不会导致PIC;3.如果2失败,这意味着Q3被切断后比Q1打开,那么PIC的IO端口能忍受多长时间12V?谢谢指教!UZSLM!
以上来自于百度翻译
      以下为原文
    system is powered by USB 5V;
PIC16F1459 is an 1-wire master,16F1459_IO1 for 1-wire communication;
16F1459_IO2 is designed to apply 12V(or 5V) programming power on the bus;
my question is:
1.will the circuit work for 16F1459_IO1 protection when 12V is applied on the 1-wire?
2.when PIC powering on,or resetting(IO2 floating),i hope the Q3 could cut off quickly(quick than Q1 turn on time,sorry for my poor english),so that 12V will be not led to PIC ;
3.if 2 failed,which mean Q3 cut off later than Q1 turned on,then how long the PIC's IO port could endure the 12V?
Thanks for advice!!
uzslm
   Attached Image(s)
回帖(1)
李亦然
2018-11-2 15:01:47
为什么470PF放置在那里?我能用PIC IO直接驱动BSS84吗?
以上来自于百度翻译
      以下为原文
    why is the 470pf placed there?
can i drive the BSS84 directly by PIC IO?
举报
更多回帖
