工程资源中心
直播中
刘鑫
7年用户 168经验值
私信 关注
[处理器/GPU]
支持64位时间戳的实时以太网跟踪器设计含原理图和物料清单
            Real-time ethernet and industrial ethernet are used in the factory automation floor to control automated production. Monitoring the ethernet traffic in such areas is an essential maintains and error analysis tool.  The TIDEP0064 reference design is a real-time ethernet tracer implementation for  (...)
主要特色
  • Monitor and trace function for industrial ethernet packets
  • Packet time stamping in nanosecond resolution
  • 64-bit time stamping supported
  • Gbit ethernet PHY uplink
  • PRU firmware and ARM driver in source code to enable customer differentiation
更多回帖
