赛灵思
直播中
王敏
8年用户 245经验值
私信 关注
[问答]
SmartXplorer ISE 13.4显示空白的智能浏览器报告窗口
你好,
我在Windows x64上运行ISE 13.4。
我最近不得不从崩溃的计算机中恢复一个项目。
我已成功读入ISE项目文件和所有相关的源文件,并已将其放置和路由。
在试图解决一些时间问题时,我试图运行SmartXploreer,但它什么也没做。
smartexplorer窗口打开以定义策略等,但单击确定它只会显示空白的智能浏览器报告窗口。
这个过程相当有帮助地说跑步失败了:smartXplorer,没有别的。
我试过建立一个全新的项目,但也没有用。
有人有任何线索吗?
问候
格雷厄姆
以上来自于谷歌翻译
以下为原文
Hullo,
I am running ISE 13.4 on windows x64.  I have recently had to recover a project from a crashed computer.  I have successfully read in the ISE project file and all of the associated source files and have got it to place and route.  In trying to address some timing issues I have tried to run SmartXploreer but it just does nothing.  The smartexplorer window opens to define the strategies etc. but on clicking OK it just does nothing but present a blank smart explorer report window.  The process rather helpfully says run failed:smartXplorer, and nothing else.
I have tried building a whole new project  and that has not worked either.  Has anybody any clues?
regards
Graham
回帖(5)
石俊梅
2018-11-2 11:35:00
嗨,
在运行smartxplorer之后的项目目录中,将创建一个名为smartxplorer_results的文件夹。
检查位于此文件夹中的smartxplorer.log文件。
这可能包含错误/警告消息。
单击选择选项并单击确定后,启动策略窗口也需要几秒钟。
等待一段时间,检查运行是否已经开始。
还要检查控制台窗口以查看是否报告了任何错误。
谢谢,
迪皮卡。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi,
In the project directory after running smartxplorer, a folder by name smartxplorer_results will be created. Check for the smartxplorer.log file located in this folder. This may contain the error/warning messages.
Also it takes few seconds to launch the strategies window after you click select the options and click on ok. Wait for some time and check if the run had started.
Also check the console window to see if there are any errors reported.
Thanks,
Deepika.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
举报
魏双艳
2018-11-2 11:43:11
嗨,
我检查了smartxplorer结果文件夹,里面没有文件。
此外,我让这件事运行了相当长的一段时间(30分钟),没有采取任何行动。
在设计层次窗口和可用进程窗口之间运行“wheel”的进程不会移动并且运行失败:smartxplorer写在它旁边而不是运行:smartxplorer。
它几乎像一个可执行文件丢失或某种配置文件丢失但显然我不知道ISE的内部工作!
问候
格雷厄姆
以上来自于谷歌翻译
以下为原文
Hi,
I have checked the smartxplorer results folder and there are no files in it.  Also I have let the thing run for quite some time (30min) with no action.  The processes running 'wheel' that sits between the design hierachy window and the available processes window does not move and has run failed:smartxplorer written next to it rather than running:smartxplorer.
Its almost like an executable is missing or some sort of config file is missing but obviously I don't know the inner workings of ISE!!
regards
Graham
举报
刘华
2018-11-2 12:00:43
我与ISE 14.4有类似的问题。
当我尝试运行SmartXplorer时,我在控制台窗口中启动了SmartXplorer,但没有进程正在运行。
smartxplorer_results目录中没有文件。
问候,
拉维
以上来自于谷歌翻译
以下为原文
I am having a similar problem with ISE 14.4.  When I try to run SmartXplorer, I get Launching SmartXplorer in the console window but there are no processes running.  There are no files in smartxplorer_results directory.
regards,
Ravi
举报
冯超
2018-11-2 12:16:30
我在Ubuntu上遇到了完全相同的问题,并尝试运行命令行版本(smartxplorer)。
原来我没有安装smartxplorer所需的库“libncurses.so.5”。在Ubuntu 64位上,“sudo apt-get install ia32-libs”修复了它。希望有所帮助!
以上来自于谷歌翻译
以下为原文
I was running into the exact same problem on Ubuntu and tried running the command line version (smartxplorer).  Turned out I did not have the library "libncurses.so.5" installed which smartxplorer needs.
On Ubuntu 64 bit, "sudo apt-get install ia32-libs" fixed it.
Hope that helps!
举报
更多回帖
