你好@ ultragreen
路由器是否因拥塞而失败?
你能上传位于.runs - > impl_1位置的runme.log文件吗?
如果失败是由于拥塞造成的,请试用ARhttps://www.xilinx.com/support/answers/66314.html上的建议。
还尝试使用增量编译,因为工作和非工作设计之间的设计变化似乎很小。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi @ultragreen
Is the router failing due to congestion? Can you upload the runme.log file located in .runs-->impl_1 location?
Try out the suggestions from AR https://www.xilinx.com/support/answers/66314.html if the failure is due to congestion.
Also try using incremental compile as the design changes between working and non-working designs seem to be minimal.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
你好@ ultragreen
路由器是否因拥塞而失败?
张贴。
以上来自于谷歌翻译
以下为原文
Hi @ultragreen
Thanks,
Deepika.
举报
