嗯,意图是一样的。
您可以使用此命令稍后使用条件创建两个端口diff。
请参阅UG835#912https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug835-vivado-tcl-commands.pdf
-Pratham ------------------------------------------------
----------------------------------------------请注意 - 请
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Well, Intent is same. You could make two ports diff later using this command but with conditions. Refer UG835 #912
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug835-vivado-tcl-commands.pdf-Pratham
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
----------------------------------------------------------------------------------------------View solution in original post
嗯,意图是一样的。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
举报
