让我感到不安的是,当你找不到下载时,你没有寻求帮助;
你立即攻击了英特尔的球。
没有证据,没有押韵或理由;
这是非常糟糕的英特尔所以把它放在他们身上。
不幸的是,这是世界运作方式的趋势。
我把这归咎于巨魔,他们不愿透露姓名,创造了一个脱敏的人口众多。
最好的例子?
诅咒你Linus Torvalds!
(只有一个名叫我知道的巨魔)。
我提供的链接是针对最新版本的英特尔MSM,我发现它(也)已经过英特尔X48台式机主板产品的验证。
我挖得更深一点,发现你可以尝试两个包。
第一个(此处:下载英特尔矩阵存储管理器)是您所拥有的稍微更新(v8.9.0.1023)的版本。
我会先尝试一下。
第二个(这里:下载英特尔快速存储技术用户界面和驱动程序)是(我认为)仍然支持X48芯片组的最新版本的英特尔RST。
要试用此英特尔RST版本,您需要完全卸载英特尔MSM软件并重新启动。
现在,无论这些版本是否适用于您的BIOS版本的RST / MSM固件,以及它们是否能够解决所遇到的问题都是一个大问题。
我将假设您也在使用主板制造商发布的最新版本的BIOS上运行。
我不知道这是否包括可用的RST / MSM固件的最新版本,或者该软件是否会克服固件错误。
所有你都可以尝试...
希望这可以帮助,
内容S
以上来自于谷歌翻译
以下为原文
What upsets me is the fact that, when you could not find the download, you didn't ask for help; you immediately attacked Intel for dropping the ball. No proof, no rhyme or reason; it's big bad Intel so lay it on them. Unfortunately, this is a trend in the way the world works. I blame this on the trolls, who in their anonymity have created a desensitized populous. Best example? Curse you Linus Torvalds! (only one of the trolls whose name I know).
The link I provided was for the last version of Intel MSM that I could find that was (also) validated with Intel's X48 Desktop Board products. I dug a little deeper and found two packages you could try. The first (here:
Download Intel Matrix Storage Manager) is a slightly newer (v8.9.0.1023) version of what you have. I would try it first. The second (here:
Download Intel Rapid Storage Technology User Interface and Driver) is (I think) the last version of Intel RST that still supported for the X48 chipset. To try this Intel RST version, you will need to completely uninstall the Intel MSM software and reboot first.
Now, whether either if these versions will work with your BIOS' version of the RST/MSM firmware and whether they will provide a fix for the issue being seen are the big questions. I will presume that you are also running on the very last version of the BIOS that the board manufacturer released. I do not know if this included the last version of the RST/MSM firmware that was made available or whether this software will overcome the firmware bug. All yu can do it try...
Hope this helps,
...S
你立即攻击了英特尔的球。
没有证据,没有押韵或理由;
不幸的是,这是世界运作方式的趋势。
最好的例子?
诅咒你Linus Torvalds!
(只有一个名叫我知道的巨魔)。
我挖得更深一点,发现你可以尝试两个包。
我会先尝试一下。
所有你都可以尝试...
希望这可以帮助,
内容S
以上来自于谷歌翻译
以下为原文
Hope this helps,
...S
举报
