工程资源中心
直播中
陈晨
8年用户 189经验值
私信 关注
[电源设计]
适用于-48V应用的125W非隔离式反相降压/升压设计图纸
            PMP20371 is a synchronous buck boost design utilizing the LM5122 for telecom applications. This design has a minimum operating input voltage of -35V and a maximum input voltage of -60V.  Switching frequency is set to 150kHz. The design is built on PMP20371 PCB, 4 layer board with 2oz copper on  (...)
主要特色
  • -35V to -60V in, output 14.5V@ 9A
  • Achieving efficiency of 93% across all operating conditions
  • Compact size, slim form factor, suitable for telecom applications
  • Solution size:  48mm x 45mm
  • LM5122 synchronous boost controller, wide input voltage, high efficiency
更多回帖
