英特尔
直播中
杨颜
8年用户 165经验值
私信 关注
[问答]
安装了Server 2016,因Windows无法识别RAID驱动器无法启动的原因?
我有一台带有Intel S1200SPS服务器主板的新服务器。
我在RAID 1虚拟磁盘上安装了Server 2016,它是在RAID BIOS(ESRT II)中使用双三星EVO 250GB SSD安装的。
RAID还配置了额外的RAID 1虚拟驱动器,包含2个2 TB的WD Gold驱动器,用于数据存储。
它运行正常,直到我把它发送给我的客户。
主板在运输中损坏,(不会启动POST)所以我用相同的型号替换它,我使用硬件诊断检查所有其他组件,包括三星SSD诊断和WD Lifeguard以确保没有其他任何损坏(正在
一定不要影响驱动器上的数据)。
诊断是在一个单独的系统上执行的,我可以单独读取驱动器,操作系统和文件都在那里。
重新组装系统后,我重新配置BIOS以使用RAID for SATA,因为它是一个新的主板,重新设置RAID 1虚拟驱动器,并将SSD RAID对设置为ESRT II BIOS中的可启动。
我对两个RAID虚拟驱动器进行了一致性检查,结果很好,修复了不一致性。
然后我将BIOS设置为从RAID阵列启动。
在这一点上,我认为它会像原来一样启动。
但是,Windows无法识别RAID驱动器,因此无法启动。
当我进入恢复模式命令提示符时,虚拟驱动器根本不可用(未在wmic logicaldisk列表中列出)。
我希望你以前英特尔公司做过这类事情并且有一个技巧可以帮助我让Server 2016重新启动,而不必浪费时间安装和配置服务器和其他软件。
有任何想法吗?
以上来自于谷歌翻译
以下为原文
I have a new server with the Intel S1200SPS server mainboard.  I installed Server 2016 on a RAID 1 virtual disk, which was setup in the RAID BIOS (ESRT II) with dual Samsung EVO 250GB SSD's.  The RAID was also configured with an additional RAID 1 virtual drive of 2 2-TB WD Gold drives for data storage.
It was working fine until I shipped it out to my client.  The mainboard was damaged in shipping, (would not power up to POST) so I replaced it with the same exact model,   I checked all other components using hardware diagnostics, including Samsung SSD diagnostics and WD Lifeguard to be sure nothing else was damaged (being sure not to affect data on the drives).  The diagnostics was performed on a separate system, and I could read the drives individually, that the OS and files are there.
After re-assembling the system, I reconfigured the BIOS to use RAID for SATA, and because it's a new mainboard, re-setup the RAID 1 virtual drives, and setting the SSD RAID pair as bootable in the ESRT II BIOS.  I did a consistency check on both RAID virtual drives, which went well, fixing inconsistencies.  I then set the BIOS to boot from the RAID Array.  At this point, I figured it would boot up as originally.  However, windows doesn't recognize the RAID drives, and so won't boot up.  When I got into recovery mode command prompt, the virtual drives are not available at all (not listed in the wmic logicaldisk list).
I'm hoping you Intel guys have done this type of thing before and have a trick up your sleeve to help me get Server 2016 to boot again and not have to lose the hours of time spent installing and configuring Server and other software.  Any ideas?
回帖(6)
汤宇
2018-10-31 16:03:33
你好,
我正在审核您的案例,我想问您一些细节,以确保信息:
A)当您的系统启动时,嵌入式RAID II配置实用程序是否显示驱动器?
B)我想确认是否在操作系统的安装过程中发生了这种情况?
您使用哪个驱动程序版本来继续使用ESRT 2安装Windows?
我想与您分享最新的驱动程序以确认信息:用于Windows *的英特尔®嵌入式服务器RAID技术2(ESRT2)RAID驱动程序请告诉我结果,以便继续下一步。
最好的祝福,
Emeth O.
以上来自于谷歌翻译
以下为原文
Hello,
I was reviewing your case and I would like to ask you some details in order to make sure the information:
A) When your system boot up does the Embedded RAID II Configuration Utility show the drives up?
B) I would like to confirm if this is happening in the middle of the installation process of the Operating System? Which driver version are you using in order to proceed with installation of windows using ESRT 2?
I would like to share with you the latest driver in order to confirm the information:
Intel® Embedded Server RAID Technology 2 (ESRT2) RAID driver for Windows*
Please, let me know the outcome in order to proceed with the next step.
Best regards,
Emeth O
举报
李玉鑫
2018-10-31 16:19:53
引用: jerry1978 发表于 2018-10-31 16:03
你好,
你好,
另外,我想与您分享以下文章;
这可能会帮助您完成一些故障排除步骤并找到此问题的解决方案:
Windows * OS无法检测基于Intel®ESRT2的RAID VolumeBest,
Emeth O.
以上来自于谷歌翻译
以下为原文
Hello,
Also, I would like to share with you the following article; this might help you with some troubleshooting steps and find the solution of this issue:
Windows* OS Doesn’t Detect the Intel® ESRT2–based RAID Volume
Best regards,
Emeth O
举报
汤宇
2018-10-31 16:30:09
引用: cd340823 发表于 2018-10-31 16:19
你好,
另外,我想与您分享以下文章;
你好,
我想知道上面提供的信息是否可以帮助您解决您遇到的这个问题。
如果您有任何其他问题,请告诉我们,我们非常乐意为您提供帮助。
最好的祝福,
Emeth O.
以上来自于谷歌翻译
以下为原文
Hello,
I would like to know if the information provided above help you out with this issue that you have been facing. If you have any other question please let us know and I will be more than happy to assist you.
Best regards,
Emeth O
举报
汤宇
2018-10-31 16:46:22
引用: jerry1978 发表于 2018-10-31 16:30
你好,
不。这里提供的信息没有帮助。
我希望那些试图帮助并发布问题答案的人会彻底阅读原帖。
我没有安装操作系统,但试图获得一个已安装操作系统的RAID阵列,在主板更换后使用相同型号再次启动。
但是,我确实找到了启动它的方法。
除非您选择安装操作系统,否则Windows 2016安装媒体不会为RAID驱动器(ESRT2驱动程序)加载驱动程序。
(也许有一种方法可以从恢复模式命令提示符中执行此操作,我不知道。也许你们其中一个人知道命令或某种方式来做到这一点?)好吧,操作系统已经安装在我的RAID驱动器上了
除非别无选择,否则我不想吹嘘。
在从安装介质引导时的恢复模式中,一个选项是从驱动器映像还原。
当我选择该选项时,操作系统找不到图像(RAID驱动器无法识别),但提供“高级”选项。
当您选择该选项时,它会为您提供加载驱动程序的机会。
因此,我使用它来加载驱动程序,关闭“从映像还原”选项,并打开命令提示符选项,然后允许恢复模式命令提示符使用wmic logicaldisk list命令“查看”RAID驱动器。
然后我使用“dism / image:c: / add-driver / driver:g: / recurse”命令让Windows在重启时重新安装RAID驱动程序。
在dism命令中,C:是操作系统分区,G:是驱动程序磁盘。
在我的例子中,wmic命令表明我的操作系统驱动器是F:,所以在dism命令中替换它。
这有效!
以上来自于谷歌翻译
以下为原文
No.  The info provided here did not help. I wish those who try to help and post answers to questions would read the original post thoroughly.  I was not installing the OS, but was trying to get a RAID array, which had the OS already on it, to boot again after motherboard replacement with the same model.
However, I did find a way to get it to boot.
Unless you choose to install the OS, windows 2016 install media doesn't give the opportunity to load drivers for the RAID drives (ESRT2 drivers).  (maybe there's a way to do it from the recovery mode command prompt, which I don't know.  Maybe one of you guys knows a command or some way to do that?)  Well, the OS had been installed on my RAID drive already, and I didn't want to blow that up unless there's no other option.
In the recovery mode while booted from the install media, one option is is to restore from a drive image.  When I chose that option, the OS doesn't find the image (RAID drives are not being recognized), but gives an "Advanced" option.  When you choose that option, it then gives you the chance to load drivers.  So, I used that to load the drivers, closed the "Restore from Image" option, and opened the command prompt option, which then allowed the recovery mode command prompt to "see" the RAID drives using the wmic logicaldisk list command.
I then used the "dism /image:c: /add-driver /driver:g: /recurse" command to have windows reinstall the RAID drivers on reboot.  In the dism command, C: is the OS partition and G: is the driver disk.  In my case, the wmic command indicated that my OS drive was F:, so substituted that in the dism command.
This worked!
举报
更多回帖
