英特尔
直播中
周丽
7年用户 233经验值
私信 关注
[问答]
请问SSD不支持的BIOS模式问题
亲爱的英特尔团队
一周前,我在较旧的SSD(840EVO)上成功安装了Optane硬件/驱动程序/软件。
然后操作系统决定破坏磁盘(与Optane无关),我不得不在新的nvme驱动器上购买并清理安装(旧的Optane仍然安装在第二个M2插槽中)。
此时我没有更改BIOS中的任何设置。
所以,我去重新安装软件以恢复和运行,现在我得到了不支持的模式错误消息。
我已经回到BIOS,检查了Optane指南的规格,并在nvme(GPT)驱动器的末尾添加了500mb未分配的插槽,但是禁用CMS会停止我的启动驱动器工作。
启动/ SATA模式:IRST / CSM尝试禁用和启用)。
最新的板卡安装V1205(或类似)
我在启动驱动器上有4个分区(SYS @ 500mb / OS @ 930gb / NTFS @ 478mb /未分配@ 496mb)/现在显示为基本MBR,即使它在安装时是GPT!
Optane磁盘显示为27.25gb未分配/基本MBR
新系统(我知道上周安装的工作)是:
华硕ROG STRIX H270F游戏
32 GB DDR4 2400
英特尔i5-7400
BOOT DRIVE:1TB NVME WD BLACK
检查已安装的Intel文件我看到:
英特尔网络连接驱动程序V22.9(在此主板上安装LAN驱动程序也是一个非常令人头疼的问题)!
英特尔管理引擎组件V11.7.0.1069
英特尔Optane Pinning Explorer Extensions V16.5.1.1030
安装日志如下:
我有点困惑,不顾一切地知道该怎么做,有人可以帮忙吗?
我每天使用我的系统16小时,我有点绝望地让事情得到解决和再次优化。
提前致谢。
DifXFrontend.log.zip
668个字节
IntelME.log.zip
5.1 K.
IntelME_MSI.log.zip
173.2 K.
IntelOptaneMemory.log.zip
13.6 K.
IntelOptaneMemory_MSI.log.zip
166个字节
以上来自于谷歌翻译
以下为原文
Dear Intel Team
A week ago on I successfully installed Optane hardware/drivers/software on an older SSD (840EVO). Then the OS decided to corrupt the disk (nothing to do with Optane) and I had to buy and clean install on a new nvme drive (with the old Optane still installed in the second M2 slot). At this point I did not change any settings in the BIOS.
So, i go to re-install the software to get things back up and running and now I get the unsupported mode error message.
I have gone back into the BIOS, checked specs against the Optane guides and added a 500mb unallocated slot to the end of the nvme (GPT) drive but disabling CMS stops my boot drive working at all. Boot/SATA mode: IRST / CSM tried both disabled and enabled). Latest BIOS for board installed V1205 (or similar)
I have 4 partitions on the boot drive (SYS@500mb / OS@930gb / NTFS@478mb / Unallocated@496mb) / Now showing as Basic MBR even though it was GPT when installed!
The Optane disk shows up as 27.25gb Unallocated / Basic MBR
New system (which I know works from last weeks install) is:
ASUS ROG STRIX H270F GAMING
32 GB DDR4 2400
INTEL i5-7400
BOOT DRIVE: 1TB NVME WD BLACK
Checking the installed Intel files I see:
Intel Network Connection Drivers V22.9 (this was also a massive headache to get the LAN drivers installed on this board)!
Intel Management Engine Components V11.7.0.1069
Intel Optane Pinning Explorer Extensions V16.5.1.1030
The install logs are as below:
I am somewhat confused and desperate to know what to do, can anyone help?
I use my system 16 hours a day and am somewhat desperate to get things solved and optimized again.
Thanks, in advance.
回帖(6)
汤宇
2018-10-31 12:11:53
嗨worldphoto42,感谢您在英特尔®社区发布。如果我理解正确,您的旧驱动器出现问题,您必须更换新驱动器,现在您想要连接英特尔®Optane™
使用这个新驱动器的内存,对吗?如果是这种情况,我必须告诉你,考虑到你当前的系统环境,这是不可能的。
英特尔®Optane™内存仅适用于SATA驱动器,不支持NVMe *驱动器,它们无法与模块配合使用。您之前的驱动器是SATA驱动器,您可以将模块与其连接,因为这个原因
但是,新驱动器是NVMe *驱动器,它不能与模块一起使用。此外,英特尔®Optane™内存设计用于加速SATA驱动器,因为SATA接口的性能,特别是在旧的HDD单元中
然而,NVMe *驱动器比SATA驱动器更快,英特尔®Optane™内存提供的加速度也没有任何差别。我希望这些信息能够澄清问题。
如果您对模块有任何疑问,请告诉我。我将非常乐意以任何方式为您提供帮助。祝您有个美好的一天。感谢,Diego V.
以上来自于谷歌翻译
以下为原文
Hi worldphoto42,
Thank you for posting in the Intel® communities.
If I understood you correctly, you had an issue with your old drive and you had to replace it with a new one, and now you would like to concatenate the Intel® Optane™ Memory with this new drive, correct?
If this is the case, I have to tell you that considering your current system environment, this won’t be possible. The Intel® Optane™ Memory works only with SATA drives, NVMe* drives are not supported and they won’t work with the module.
Your previous drive was a SATA drive, and you were able to concatenate the module with it because of this reason, however the new drive is an NVMe* drive and it won’t work with the module.
Additionally, the Intel® Optane™ Memory has been designed to accelerate SATA drives due to the performance of the SATA interface, especially in the old HDD units, however an NVMe* drive is faster than a SATA drive and the acceleration provided by the Intel® Optane™ Memory wouldn’t do any difference.
I hope this information has clarified the concern. Please let me know if you have further questions about the module, I’ll be more than glad to assist you in any way I can.
Have a nice day.
Regards,
Diego V.
举报
李玉鑫
2018-10-31 12:30:04
英特尔®Optane™内存仅适用于SATA驱动器,不支持NVMe *驱动器,它们无法与 ...
你好迭戈
感谢您的快速回复。
我从未考虑过,因为我的原始驱动器是完全兼容的。
谢谢你的清晰度。
那么,我可以使用Optane模块:
A)另一个快速nvme驱动器?
要么
B)加速另一个(3.5“)SATA驱动器我广泛用于文件(或者如果我修复并重新安装其他SSD可以用Optane进行优化,即使我的启动驱动器没有分配给它)?我还有6个其他3.5驱动器
在系统中用于各种用途:临时磁盘/ photoshop,存档,备份,文档等...
要么
C)它可以单独加速系统内存吗?
如果可能的话,我想尝试使用技术 - 我有任何选择吗?
谢谢
巴蒂尔
以上来自于谷歌翻译
以下为原文
Hi Diego
Thanks for the quick reply.
I never even considered that as my original drive was fully compatible. Thanks for your clarity.
So, could I use the Optane module for either:
A) another fast nvme drive?
or
B) to accelerate another (3.5") SATA drive I use extensively for files (or if I fix and reinstall the other SSD could that be optimised with Optane even if my boot drive is not assigned to it)? I have 6 other 3.5 Drives in the system for various uses: scratch disk/photoshop, archive, back-up, docs etc...
or
C) can it accelerate system memory alone?
I would like to try and use the tech if possible - do I have any options?
Thanks
Shane
举报
汤宇
2018-10-31 12:47:48
引用: cd340823 发表于 2018-10-31 12:30
你好迭戈
感谢您的快速回复。
嗨worldphoto42,您可以使用Intel®Optane™内存加速主驱动器或辅助驱动器,只要它是SATA驱动器即可。
这意味着NVMe *驱动器不是一个选项,也不是单独加速系统内存。在之前的设置中,您正在加速SATA主驱动器。
现在,由于您有一个新的主驱动器,即NVMe *驱动器,可用选项是加速辅助SATA驱动器,但加速辅助驱动器涉及其他细节。辅助驱动器加速的第一个要求是驱动程序版本以及
处理器和芯片组。
第8代处理器支持辅助驱动器加速。
您目前正在使用带有芯片组H270的第7代处理器。
此配置不支持辅助加速,但是有可能通过包含英特尔®RSTPre OS UEFI驱动程序16.0.2.3402的BIOS更新,支持辅助驱动器加速。您可以直接与主板制造商在
以下站点:https://www.asus.com/us/Motherboards/ROG-STRIX-H270F-GAMING/此外,要加速的辅助驱动器不能安装任何操作系统,并且必须具有GPT分区。
您可以在以下文章中查看更多信息:https://www.intel.com/content/www/us/en/support/articles/000027987/memory-and-storage.htmlHave说这个,第一个建议是
确认BIOS更新包含所需的驱动程序版本,或确认您是否已在BIOS中安装了所需的版本。我希望您发现此信息有用。如果您有任何其他问题,请告诉我。祝您有个愉快的一天。
.Regards,Diego V.
以上来自于谷歌翻译
以下为原文
Hi worldphoto42,
You can, with the Intel® Optane™ Memory, accelerate a primary drive or a secondary drive as long as it’s a SATA drive. This means that NVMe* drives are not an option nor accelerating system memory alone.
In your previous setup, you were accelerating a SATA primary drive. Now, since you have a new primary drive which is the NVMe* drive, the option available is to accelerate a secondary SATA drive, however accelerating secondary drives involve other details.
The first requirement for secondary drive acceleration is the driver version as well as the processor and chipset. The secondary drive acceleration is supported in 8th generation processors. You are currently using a 7th generation processor with the chipset H270. This configuration doesn’t support secondary acceleration, however it may be possible that with a BIOS update that includes the Intel® RST Pre OS UEFI driver 16.0.2.3402, the secondary drive acceleration is supported.
You can check this directly with your motherboard’s manufacturer at the following site: https://www.asus.com/us/Motherboards/ROG-STRIX-H270F-GAMING/
Additionally, the secondary drive that is going to be accelerated, cannot have any OS installed and must have a GPT partition.
You can check additional information in the following article: https://www.intel.com/content/www/us/en/support/articles/000027987/memory-and-storage.html
Having said this, the first recommendation would be to confirm there is a BIOS update that includes the driver version required, or to confirm if you already have the version required installed in the BIOS.
I hope you find this information useful.
Let me know if you have any further questions.
Have a nice day.
Regards,
Diego V.
举报
周丽
2018-10-31 13:01:03
你好迭戈
感谢您的快速回复。
嗨worldphoto42,我想知道我是否澄清了您对英特尔®Optane™内存的疑虑,或者我还能为您提供什么帮助.Regards,Diego V.
以上来自于谷歌翻译
以下为原文
Hi worldphoto42,
I’d like to know if I have clarified your concerns regarding to the Intel® Optane™ Memory, or if there is anything else I can help you with.
Regards,
Diego V.
举报
更多回帖
