此博客旨在讨论村田制作所的LBWA1UZ1GC-901 WiFi模块,也称为IMP005,这是一种端到端设备,可以将传感器或专有设备连接到互联网。
通过Imp Imp完成
通信,Imp Cloud是Electric Imp提供的基于云的服务。
该模块还集成了硬件,操作系统,安全性和API。
该模块工作在2.4 GHz和5 GHz,并具有
ARM Cortex-R4处理器。
它采用3.3 V
电源电压,具有用于主机接口的UART / SPI / USB协议,并遵循802.11a / b / g / n WLAN标准。
IMP005不直接将设备放在互联网上。
设置平台,以便设备与安全的Imp Cloud进行通信,然后与Internet进行通信。
此设备上使用的任何代码都将在云中编译。
为了帮助构建软件应用程序,有一个API提供类和全局对象,因此设备和代理程序代码可以访问本地硬件和云功能。
由于所有应用程序代码都是在Imp Cloud中编译的,因此IMP005将能够专注于其输入和输出引脚而不是处理信息。
这是将产品安全地连接到互联网的好方法。
云由Electric Imp管理,因此制造商可以专注于更快地将产品推向市场。
通过推出使用LBWA1UZ1GC-901模块的IMP005-BREAKOUT,Electric Imp和Murata联手帮助正在开发产品的工程师。
此设备的IDE是基于Web的,因此不需要昂贵的程序,只能在单个PC上运行或需要许可证才能运行。
此外,如果模块通过网络连接到imp云,则可以在世界任何地方进行处理。
以上来自于谷歌翻译
以下为原文
This blog is meant to talk about
Murata’s LBWA1UZ1GC-901 WiFi module, also known as the IMP005, an end-to-end device that will allow a sensor or piece of proprietary equipment to be connected to the internet. Communica
tion is accomplished through the
Imp Cloud which is a cloud-based service offered by
Electric Imp. The module has integrated hardware, an operating system, security, and API’s as well.
The module operates at 2.4 GHz and 5 GHz and has an ARM Cortex-R4 processor. It takes a 3.3 V supply voltage, has UART/SPI/USB protocols for a host interface, and follows the 802.11a/b/g/n WLAN standard. The IMP005 does not directly place a device on the internet. The platform is set up so that the device communicates with the secure Imp Cloud then to the internet. Any code used on this device will be compiled in the cloud. To help with building software applications, there is an API that provides classes and global objects so the device and agent code can access local hardware and cloud functionality. Since all of the application code is compiled in the Imp Cloud, the IMP005 will be able to focus on its input and output pins rather than on processing information.
This is a great way to get a product securely connected to the internet. The cloud is managed by Electric Imp so manufacturers can focus on getting products to market faster. Electric Imp and Murata have teamed up to help the engineer who is in the process of developing a product by introducing the
IMP005-BREAKOUT which uses the LBWA1UZ1GC-901 module. The IDE for this device is web based so there is no need for an expensive program that can only run on a single PC or that needs a license to operate. Additionally, if the module is connected through a network to the imp cloud, it can be worked on from anywhere in the world.
