您是否发现自己需要拼接或接入电线,但不确定如何继续?
当你学习时,这可能是一个棘手的任务,尤其是攻丝。
在本文中,我将介绍两者的正确步骤,以及一些使这个过程更容易的技巧。
有几种不同的方法来拼接电线。
可能最常见的是剥去两根电线(将它们剥开足够长的时间,以便有足够的裸线工作),将它们彼此扭转,焊接,并在接头上放置热缩管。
记得在焊接前放置热缩管,否则电气胶带就足够了。
还有一些不需要任何焊接的电线接头连接器。
攻丝是有点棘手的。
当然有T-Splice连接器使这个过程更容易一些。
但是,这并不总是一种选择,因此需要去除绝缘。
为此,使用适当尺寸的剥线钳在要移除的长度的每一侧的绝缘层中放置切口,然后小心地使用剃刀刀片去除切口之间的绝缘层。
一旦完成,将线股分开足以将新线穿过中心(拾取器或小螺丝刀使其变得容易),然后包裹并焊接。
如果导线未绞合,则只需缠绕导线并焊接。
从这一点开始,您需要用热缩管或电工胶带覆盖电线。
如果首选视觉表示,请转到此视频,我们的技术人员将演示该过程。
以上来自于谷歌翻译
以下为原文
Have you found yourself needing to splice or tap into wires, but aren’t sure exactly how to proceed? This can be a tricky task when you are learning, especially tapping wires. In this ar
ticle, I will go over the proper procedure for both, along with some tricks to make the process a little easier.
There are a few different ways to splice wires. Probably the most common is to strip the two wires (strip them long enough so you have enough bare wire to work with), twist them around each other, solder, and place heatshrink over the joint. Remember to put the heatshrink on before soldering, otherwise electrical tape will suffice. There are also wire splice connectors that don’t require any soldering.
Tapping wires is a little tricky. There are of course T-Splice connectors that make this process a little easier. However, that’s not always an option, so insulation will need to be removed. To do this, use a wire stripper of the appropriate size to place a cut in the insulation on each side of the length to be removed, then carefully use a razor blade to remove the insulation between the cuts. Once that’s done, part the strands enough to insert the new wire through the center (a pick or small screwdriver makes this easy), then wrap and solder. If the wire isn’t stranded, then just wrap the wire and solder. From this point you’ll need to either cover the wire with heatshrink or electrical tape.
If a visual representation is preferred, head over to this
video where one of our technicians will demonstrate the process.
