对于那些错过我的第一篇博客的人来说,“品尝力量!
- 实验1“,我最近获得了Charles Platt的第二版”Make:Electronics“,并决定尝试本书中提供的所有实验。
这是我对第二个实验结果的记录。
在我们开始之前,对于那些可能在考虑忽略普拉特先生的建议并希望了解当您使用锂电池时会发生什么的人,请观看这个真棒视频:
如何吹保险丝
我使用了两种不同的1.5 V AA全新电池,但不幸的是,我无法吹掉3 A保险丝(我甚至尝试使用9 V电池)。
幸运的是,我家里有一个1 A保险丝,它确实烧坏了,但只是直接将电池座的电线连接到它上面。
我无法用测试引线烧断保险丝的原因可能是一些廉价的测试引线不允许足够的电流流过它们。
到目前为止,这本书已经向我们介绍了电池和保险丝。
要了解有关这些组件的更多信息,您可以查看Charles Platt的“
电子元件百科全书第1卷”的第2章和第4章。
如果您想自己重新创建这个实验,您可以从Digi-Key获得此实验所需的一切!
1.5 V AA电池
电池架
3 A汽车保险丝
护目镜
测试导线两端各有鳄鱼夹
额外
如果您想更多地探讨这个主题,请查看下面的链接。
为什么锂离子电池会爆炸
https://www.howtogeek.com/338762/why-do-lithium-ion-batteries-explode/
保险丝类型
https://www.electronicshub.org/fuses-types-fuses/
电池如何工作
https://www.youtube.com/watch?v=9OVtk6G2TnQ
亚历山德罗·沃尔塔 - 电池
https://www.youtube.com/watch?v=Is8wAeoTqHQ
固态电子产品
https://en.wikipedia.org/wiki/Solid-state_electronics
表面贴装技术
https://en.wikipedia.org/wiki/Surface-mount_technology
交流
电源插头和插座
https://en.wikipedia.org/wiki/AC_power_plugs_and_sockets
Voltaic堆
https://libraries.mit.edu/collec
tions/vail-collection/topics/electricity/the-voltaic-pile/
以上来自于谷歌翻译
以下为原文
For those of you who missed my first blog, “
Taste the Power! – Experiment 1”, I recently got the second edition of
“Make: Electronics” by Charles Plattand decided to try all of the experiments presented in the book. This is my documentation of how the second experiment turned out.
Before we begin, for those who might be thinking of ignoring Mr. Platt’s advice and want to see what happens when you short a lithium battery, just watch this AWESOME video instead:
How to blow a fuse
I used two different 1.5 V AA brand new batteries, but unfortunately, I was unable to blow the 3 A fuse (I even tried with a 9 V battery).
Luckily, I had a 1 A fuse at home, which did burn, but only by applying the wires from the battery holder to it directly.
The reason I wasn’t able to blow the fuse with the test leads could be that some cheap test leads don’t allow enough current to flow through them.
The book has so far introduced us to batteries and fuses. To learn more about these components you can check out chapters 2 and 4 of Charles Platt’s
“Encyclopedia of Electronic Components Volume 1”.
If you would like to recreate this experiment yourself, you can get everything you need for this experiment from Digi-Key!
EXTRA
If you would to explore this topic some more, check out the links below.
Why do Lithium-ion batteries explode
Types of fuses
How batteries work
Alessandro Volta – The Battery
Solid state electronics
Surface mount technology
AC Power plugs and sockets
The Voltaic pile
https://libraries.mit.edu/collections/vail-collection/topics/electricity/the-voltaic-pile/
