新技术使您可以在降低生产成本的同时增加产品功能。
我们在Digi-Key Electronics的目的是储存最新和最好的技术,以支持您创建最现代,最具特色和最低成本设备的旅程。
牢记这一目标,我今天要展示的两种产品可以协同工作(例如,在物联网设计中)或单独针对任意数量的应用程序。
希望我提供的简要概述将激发一个想法或推动您挖掘有关这些和其他产品的更多信息。
我今天的第一个项目来自一家名为RECOM的知名电力供应商。
该升压型开关稳压器(R-78S3.3-.01)将从单节AAA或纽扣电池(.65 V至3.15 V)输入输入电压,输出3.3 V,电压约为100 mA,效率为93
满载时%。
随着电池输出逐渐下降,升压调节器将输出保持稳定在3.3 V,直到达到.65 V的最小输入阈值。该器件非常适合需要稳定3.3 V输出的电池供电IoT应用。
Scott,我们的应用工程师之一,在他的R-78S3.3-.01博客文章中进一步详细介绍。
我今天的最后一个产品是Taiyo Yuden的蓝牙5.0模块(EYSHSNZWZ)。
该BLE模块在单个封装中集成了Nordic Semiconductor nRF52832蓝牙低功耗芯片,
ARM Cortex M4F处理器和集成的高性能
PCB天线。
除了它的许多功能之外,这个模块非常小;
实际上,六个可以放在一角钱的脸上。
它体积小,功率要求低,适用于任何“智能”应用以及心率,压力或血糖监测应用 - 仅举几例。
Scott的蓝牙5.0博客文章详细介绍了Taiyo Yuden模块。
您能为这些产品想到哪些有趣的应用?
请在下面的评论中告诉我们。
谢谢观看!
以上来自于谷歌翻译
以下为原文
New technology allows you to increase the func
tionality of your product while lowering production costs. Our purpose here at Digi-Key Electronics is to stock the latest and greatest technology to support your journey to create the most modern, the most featured, and the lowest possible cost devices you can. Keeping that purpose in mind, the two products I have to showcase today could work together (in an IoT design for instance) or separately targeting any number of applications. Hopefully the brief overview I provide will spark an idea or push you to dig for more information on these and other products.
The first item I have today is from a well-known power supplier called
RECOM. This
step-up switching regulator (R-78S3.3-.01) will take an input voltage from a single AAA or coin cell battery (.65 V to 3.15 V) and output 3.3 V at around 100 mA with an efficiency of 93% at full load. As your battery output gradually declines, the step-up regulator keeps the output at a stable 3.3 V until passing the minimum input threshold of .65 V. This device is a perfect fit for battery powered IoT applications that require a stable 3.3 V output. Scott, one of our Applications Engineers, goes in to further details in his
R-78S3.3-.01 blog post.
The last product I have today is a
Bluetooth 5.0 module (EYSHSNZWZ) from
Taiyo Yuden. This BLE module incorporates the Nordic Semiconductor nRF52832 Bluetooth Low Energy chip, an ARM Cortex M4F processor, and an integrated high performance PCB antenna in a single package. On top of its many features, this module is extremely small; so small, in fact, six can fit on the face of a dime. Its small size and low power requirements make it suitable for any “smart” application as well as heart rate, pressure, or blood glucose monitor applications—just to name a few. Scott's
Bluetooth 5.0 blog post goes in to detail on the Taiyo Yuden module.
What interesting applications can you think of for these products? Let us know in the comments below. Thanks for watching!
