SparkFun Pioneer IoT Shield(图片来源:Digi-Key Electronics)
这是春天,所以这意味着它是时候开始你的花园了。
但是在北方,我们没有适合所有植被的气候,因此我们使用温室来帮助创造理想的环境。
当然,我们希望监控我们的小环境,以确保我们拥有正确的气候。
好吧,赛普拉斯和SparkFun让我们满意。
赛普拉斯发布了新的PSoC 6,并与SparkFun和Digi-Key合作,为PSoC产品线制造了先锋物联网屏蔽。
PSoC 6具有集成的BLE和Pioneer屏蔽以及Xbee封装,使我们能够制作一个非常快速简便的物联网网关。
SparkFun有一个使用PSoC 6,Pioneer IoT屏蔽,PSoC 4,环境传感器,Wi-Fi Xbee和Thingspeak网站的项目。
这是一个用于远程监控温室的伟大项目。
只需对代码进行一些修改,我们就可以添加第二个PSoC 4并获得我们想要的数据并使其易于阅读。
让多个PSoC 4传感器节点向PSoC 6网关发送数据使我们能够覆盖更广泛的区域,或检查多个区域。
该项目非常适合物联网入门。
SparkFun Pioneer IoT防护罩是与传感器阵列进行交互的绝佳方式。
赛普拉斯PSoC系列微控制器,特别是新的PSoC 6,是使内置BLE实现物联网网络的好方法。
如果您想开始制作自己的物联网网络,请查看这些产品以快速运行项目。
以上来自于谷歌翻译
以下为原文
The SparkFun Pioneer IoT Shield (Image source: Digi-Key Electronics)
It is spring
time, so that means it’s time to start your gardens. But up here in the north we don’t have the correct climate for all vegetation, so we use a greenhouse to help create the desired environment. Naturally, we will want to monitor our little environment to make sure we have the correct climate. Well,
Cypress and
SparkFun have us covered. Cypress has released their new
PSoC 6 and partnered with SparkFun and
Digi-Key to make the
Pioneer IoT shield for the PSoC line. The PSoC 6, with its integrated BLE and Pioneer shield with Xbee footprint, allows us to make a very quick and easy IoT gateway.
SparkFun has a
project that uses the PSoC 6, Pioneer IoT shield, a
PSoC 4, environmental sensor, Wi-Fi Xbee, and the website Thingspeak. This is a great project for remote monitoring of a greenhouse. With just a little modification to the code, we can add a second PSoC 4 and get just the data we want and make it easily legible. Having multiple PSoC 4 sensor nodes sending data to our PSoC 6 gateway allows us to cover a much wider area, or to check multiple areas.
This project is perfect for getting started with IoT. The SparkFun Pioneer IoT shield is a great way to interact with an array of sensors. The Cypress PSoC line of microcontrollers, especially with their new PSoC 6, is a great way to get a IoT network going with the built-in BLE. If you want to start making your own IoT network, take a look at these products to get a project running quick.
