Microchip
直播中
h1654155275.5697
7年用户 615经验值
私信 关注
[问答]
怎么在Curiosity EVB上运行示例项目
嗨,我一直在好奇好奇的EVB和Explorer 16/32(使用MPLAB X IDE)。就我所见,需要一些外部模块(即,中继点击,ADC单击…)来运行它们。然而,我试图在没有ADC点击的情况下执行ADC转换。看一下ADC模块的框图,我想不出模拟引脚(AN0 AN13)和好奇心板(RAX/BX/CX)上的物理引脚之间的关系。有人能帮助我理解如何使用CP吗?你的模数转换器?或者,不使用ADC点击的MPLAB-X项目是WelCAM.tiA。
以上来自于百度翻译
      以下为原文
    Hi,
I've been fooling around with the Curiosity EVB and Explorer 16/32 (using MPLAB X IDE). As far as I can see, some external modules are needed (i.e. Relay Click, ADC Click ...) in order to run them. However, I'm trying to perform an ADC conversion WITHOUT the ADC Click.
Looking at the block diagram of the ADC module, I can't figure out the relations between the analog pins (AN0-AN13) and the physical pins on the Curiosity board (RAx/Bx/Cx).
Can someone please help me understand how to use the CPU's ADC? Alternatively, an MPLAB-X project which does not use the ADC click is welcome.
TIA.
回帖(1)
贾飞小
2018-10-26 16:24:58
您不需要使用继电器点击、ADC点击或任何点击来与您的好奇心板一起玩。好奇心在您的ADC上可以使用BurdAdCondiod电位器,您可以通过扩展连接器获得其他引脚,您可以使用一些跳线和连接Exter的插件板。你可以从好奇心提供的样本代码开始。
以上来自于百度翻译
      以下为原文
    You don't need to use Relay clicks, ADC click or any click to play around with your curiosity board.
The curiosity has on board analog potentiometer you can use for your ADC, you can get access to other pins via the expansion connector, you can use a breadboard with some jumper wires and connect external sensors to your board.
You can start with Curiosity supplied sample codes
举报
更多回帖
