你好ImadDarkness,
感谢您在英特尔®社区发帖。
我在以下站点检查了您的笔记本电脑型号的信息,但我没有找到任何有关英特尔®Optane™内存的参考:ROG GL553VD |
游戏笔记本电脑 - 华硕美国,因此我认为您的系统与模块不兼容,因为华硕*通常会在产品规格中添加对模块的引用。
考虑到这些信息,我检查了与模块配合使用的兼容芯片组,系统中使用的芯片组(英特尔®HM175高速芯片组)不在列表中。
这意味着您的系统与Intel®Optane™内存不兼容。
这就是您收到英特尔®Optane™应用程序消息的原因。
您可以在以下站点中查看芯片组兼容性列表:英特尔®Optane™内存的软件和平台支持
我希望这澄清了你的询问。
如果还有什么我可以帮到你,请告诉我。
祝你今天愉快。
此致,Diego V.
以上来自于谷歌翻译
以下为原文
Hi ImadDarkness,
Thank you for posting in the Intel® communities.
I was checking the information of your laptop model in the following site, but I didn’t find any reference to the Intel® Optane™ Memory:
ROG GL553VD | Gaming Laptop - ASUS USA , so that made me think that your system is not compatible with the module as ASUS* usually adds references to the module in the product specifications.
Considering this information, I checked the compatible chipsets that work with the module and the one used in your system (
Intel® HM175 Express Chipset) is not in the list. This means that your system is not compatible with the Intel® Optane™ Memory. That’s the reason of the message that you are getting in the Intel® Optane™ Application.
You can check the chipset compatibility list in the following site:
Software and Platform Support for Intel® Optane™ Memory
I hope this clarified your inquiry. Please let me know if there is anything else I can help you with.
Have a nice day.
Regards,
Diego V.
你好ImadDarkness,
感谢您在英特尔®社区发帖。
我希望这澄清了你的询问。
如果还有什么我可以帮到你,请告诉我。
祝你今天愉快。
此致,Diego V.
以上来自于谷歌翻译
以下为原文
Hi ImadDarkness,
Have a nice day.
Regards,
Diego V.
举报
