嗨lham和Dr_joel,我在这里有同样的问题。
我想对测量数据进行一些数学运算,所以我决定将修正后的数据保存到touchstone文件中。
对于我的测试设置,我使用带有四个端口的E5071C NWA,并通过固件中的“Save to SnP”按钮将数据直接保存到S4P文件中。
它工作正常,但上次我将跟踪数据单独保存到单个CSV文件中,并且惊讶于有比S4P文件更多的小数。
例如,这里是我的S4P文件中有关单个参数的报价(S11)和单个频率,格式为LOG / Phase两种情况(仅LOG,未显示相位):300000-1.408585e + 001引用的相同参数
CSV:300000-14.0858484053迹线上没有额外处理(仅完整的4端口OSLT校准)。
似乎S4P输出四舍五入到小于CSV的小数,可能为指数提供空间。
有没有办法在S4P输出中更改小数或禁用指数?
试金石格式本身不限于单一或双精度的单一格式以及指数的使用。
非常感谢任何提示或建议,最好的问候,蒂姆
以上来自于谷歌翻译
以下为原文
Hi lham and Dr_joel,
I have the same issue here. I want to do some math operation on the measured data, so I decided to save the corrected data into touchstone files. For my test setup I use a E5071C NWA with four ports and save the data into S4P file direct through the "Save to SnP" button in firmware. It works fine, but last time I saved the trace data seperate into single CSV files and was surprised that there are more decimals than in the S4P file.
For example here is a quote from my S4P file for a single parameter (S11) and a single frequency, format is LOG/Phase in both cases (only LOG, no phase shown):
300000 -1.408585e+001
The same parameter quoted from CSV:
300000 -14.0858484053
There has been no extra processing on the traces (only full 4 port OSLT calibration). It seems that the S4P output is rounded to fewer decimals than the CSV, maybe to give space for the exponent. Is there a way to change the decimals or disable the use of exponent in S4P output? The touchstone format itself is not limited to a single format like single or double precision and the use of exponent.
Thanks a lot for any hint or advise,
best regards,
Tim
以上来自于谷歌翻译
以下为原文
best regards,
Tim
举报
