你好,
您可以通过使用UCF约束将BUFIO2放置在正确的站点中来解决此问题:
INST“instance_name”LOC =位置;
即,INST“BUFIO2_inst”LOC = BUFIO2_X3Y7;
您可以在UG382中获得正确的BUFIO2位置
谢谢,
维奈
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hello,
You can overcome this issue by placing the BUFIO2 in the correct site by using UCF constraint:
INST “instance_name” LOC=location;
i.e., INST "BUFIO2_inst" LOC=BUFIO2_X3Y7;
You can get the correct BUFIO2 location in UG382
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
你好,
谢谢,
维奈
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hello,
Thanks,
Vinay
举报
