英特尔
直播中
杜云
8年用户 307经验值
私信 关注
[问答]
Powershell模块TLS无法正常工作
大家好...
我在使用PowerShell与我的Intel AMT设备进行通信时遇到问题。
它之前一直工作得很好,但现在我得到一个Schannel错误70(协议错误)
我想这是因为Intel AMT不再支持TLS 1.0了。
我怎样才能让poweshell模块再次运行?
客户端的AMT版本为12.0.6,FW为12.0.6.1120
请指教
/海涅
以上来自于谷歌翻译
以下为原文
Hi All...
I'm having issues using powershell to communicate with my Intel AMT devices.
It's been working just fine before, but now i get a Schannel error 70 (protocol error)
I guess it's because of Intel AMT not supporting TLS 1.0 any longer.
How can i get the poweshell module to work again?
The AMT version on the client is 12.0.6 and FW is 12.0.6.1120
Please advice
/Heine
回帖(9)
汤宇
2018-10-24 15:35:11
Helloheinekmadsen,我想告知英特尔SCS 12.0已经弃用了用于英特尔®AMT的英特尔®SCS通信的TLS 1.0安全协议,因为TLS 1.0协议已经识别出安全漏洞。
如果您想了解更多相关信息,请参阅以下第3.13节中的以下PDF文件:http://www.intel.com/content/dam/support/us/en/documents/
software / Intel_SCS_User_Guide.pdf如果您有任何其他问题,请告诉我,我将非常乐意为您提供帮助。最好的问候,
Emeth O.
以上来自于谷歌翻译
以下为原文
Hello heinekmadsen,
I would like to inform that Intel SCS 12.0 has deprecated the TLS 1.0 security protocol for Intel® SCS communication with Intel® AMT, due to the fact The TLS 1.0 protocol has identified security vulnerabilities.
If you would like to know more information about it, I would like to refer you to the following PDF File in the section 3.13.
https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf
Please if you have any other question, let me know and I will be more than happy to assist you.
Best regards,
Emeth O
举报
李玉鑫
2018-10-24 15:44:00
software / Intel_SCS_User_Guide.pdf如果您 ...
嗨,
您是否阅读了我的完整帖子并查看了截图?
似乎你只是重复了我自己的发现,因为我还说不再支持TLS 1.0。
我的问题是让PowerShell模块工作,现在TLS1.0被删除了,模块似乎默认为TLS 1.0(纠正我,如果我错了)
我需要的是一个PowerShell模块,能够在新版本12中使用TLS。当前模块似乎已经过时了。
/海涅
以上来自于谷歌翻译
以下为原文
Hi,
Did you even read my full post and viewed the screenshots?
Seems like you just repeated my own findings as i also state that TLS 1.0 is no longer supported.
My issue is getting the powershell module to work now thet TLS1.0 is depricated, and the module seems to default to TLS 1.0 (Correct me if i'm wrong)
What I need is a powershell module that's able to use TLS with the new version 12. The current module seems outdated.
/Heine
举报
汤宇
2018-10-24 15:57:42
引用: cd340823 发表于 2018-10-24 17:27
嗨,
您是否阅读了我的完整帖子并查看了截图?
你好,
好的,请接受我对误解的道歉。
我将调查有关您正在寻找的信息的更多详细信息,以便为您提供最准确的答案。
祝你有美好的一天。
最好的祝福,
Emeth O.
以上来自于谷歌翻译
以下为原文
Hello,
Ok, please accept my apologize for the misunderstanding.
I am going to investigate more details about the information that you are looking for in order to provide you the most accurate answer about it.
Have a wonderful day.
Best regards,
Emeth O
举报
杜云
2018-10-24 16:09:18
引用: jerry1978 发表于 2018-10-24 17:40
你好,
好的,请接受我对误解的道歉。
你好,
我正在审查您遇到的有关此问题的一些详细信息,我想告诉您问题是powershell模块仅支持TLS 1.0和1.0。请求将升级powershell功能以支持TLS 1.1和
1.2。
不幸的是,这不是一夜之间发生的事情。但是,让我问你一件事:
您最近是否升级了系统?您是否使用旧系统使用较旧的AMT固件?您之前是否在没有TLS的情况下连接并且最近实施了TLS?我将等待您的结果以继续下一步。
最好的祝福,
Emeth O.
以上来自于谷歌翻译
以下为原文
Hello,
I was reviewing some details about this issue that you have been facing and I would like to let you know that the problem is that the powershell module supports TLS 1.0 and 1.0 only.The request will be to upgrade the powershell capability to support TLS 1.1 and 1.2.  Unfortunately, this is not something that happens overnight.
However, let me ask you something:
Did you upgrade the system recently?
Did you were using an older system with an older AMT firmware?
Did you connect previously without TLS and just recently implemented TLS?
I will be waiting your outcome in order to proceed with the next step.
Best regards,
Emeth O
举报
更多回帖
