工程资源中心
直播中
童霏
7年用户 183经验值
私信 关注
[能源收集]
快速充电器解决方案PMP40183包括BOM及层图
            The PMP40183 reference design is a fast charger solution with secondary-side regulation using UCC28740 which provides Constant-Voltage Constant-Current. The design supports maximum 15V/3A PD 3.0 standard and also 6.2V-11V/4A output power level. This output performance will enable fast charge between  (...)
主要特色
  • Valley switching operation and VS balance S.R flyback
  • System level solution for cable impedance detection and BAT OVP co-working with BQ25970
  • Supports 6.2V-11V/4A
  • Support standard PD 3.0 5V,9V,15V/3A
  • Vbus adjustable with 20mV/step resolution
更多回帖
